587,760 active members*
2,767 visitors online*
IndustryArena Forum > CAM Software > OneCNC > synchronized axes feedrate
    Mar 2011
    0
    I am trying to do some surfacing on a brigdeport with a simens shopmill 840D control but its not maintaining the feedrate, it keeps slowing down when changing direction. Does anyone know how I can solve this issue thanks.
    I am programming with Onecnc xr4 pro
    4826
    Some controllers have settings that deliberately slow the machine when changing direction. But if that is not this case, then maybe it is due to the control getting bogged down processing many short movements. Depending on the type of machining operation you have set up, and your post settings, your post could be posting simulated arcs in the form of short line segments. A sample xfa file would be helpful to look at.
    Mar 2011
    0
    Thanks for the reply, I found the answer, in programme edit, select milling on the soft keys and select options on the L/H side and highspeed settings, in there you can adjust the tolerance when surfacing. Worked a treat.
  1. Slave not synchronized
    By Træstøv in forum Machines running Mach Software
    Last Post: 08-15-2011, 06:07 AM
  2. Synchronized PWM
    By moonrock in forum Stepper Motors / Drives
    Last Post: 08-11-2008, 11:22 PM
  3. Lathe: Synchronized C/X axis programming
    By toastydeath in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-17-2008, 03:58 PM
  4. Does anyone know of a controller board for synchronized stepper motors
    By Yellowbeard in forum Stepper Motors / Drives
    Last Post: 04-04-2005, 05:06 AM
  5. Looking for controller board for synchronized stepper motors
    By Yellowbeard in forum CNC Machine Related Electronics
    Last Post: 04-02-2005, 03:50 PM
