587,283 active members*
4,403 visitors online*
Results 1 to 7 of 7
    Mar 2011
    0
    Syil C6-B CNC lathe
    Good day!
    Does anyone have advice or information reguarding the cnc lathe? Can anyone provide info or insight about it?
    Also where i could search for info that may already be posted?
    kyle
    Apr 2007
    157
    Hey There! I have a Syil America C6; its about 5+ years old. It has Never caused me any problems. I have it tooled with Dorian Kennametal and Valanite tool holders along with a AXA QC Tool Post. If you get the Lathe take the crosslide off and put it in the dumpster!
    Tool it up rite and it will hold .0005 all day long...
    Some where on this Syil forum are some pics of a Turret I made for my Lathe too.
    Just piddeling around saw a picture and made it...with the C6 and SX3 Mill..
    Mar 2011
    0
    Where do you suggest i get a different cross slide? Also is a tool turret available for purchase?
    thanks very much!
    kyle
    Apr 2007
    157
    I was wrong to say take the Crosslide off...I was meaning the Compound Slide...I don't know of any turrets for sale. I posted a pic of the one I made..It works great if you are going to make hundreds of parts...but as for ones and twos..it takes more time to set it up.
    6855
    That is what I need.
    Nov 2008
    147
    Re: Syil C6-B CNC lathe
    anybody have any better details of that tool changer. Also, will that SYIL C6 compare to my current Grizzly 11X26. Is it lighter and flimsier? I've matsreed what I can and can not do on that machine, but its time for a controller. I need something that will control rpm and is repeatable, does curves etc etc. I'm looking into a used unit.
    Jul 2004
    1424
    Syil C6 is an adaption of the Sieg C6. Grizzly sells the C6 as their G0516 combo machine. 10x21" makes it slightly smaller dimensions than your 11x26, but the same weight, probably acts about the same. FWIW, the Sieg C6 seems to be favored over the 11x26 by the crowd that buys that class of machine. That is only my opinion based upon what I have read over the years.
    Grizzly.com
    I don't believe that Syil sells the C6 anymore, they have moved onto a slightly different machine, the EX250, which looks like it was designed from the ground up for cnc rather than retrofitting a manual mill. It is also much smaller (10x16) and lighter (300# vs. 500#). Of note, Novakon sells a similar machine (10x17), although much heavier (probably because it includes the base).
  1. Syil - Slant bed lathe
    By chevalier in forum Syil Products
    Last Post: 04-09-2013, 04:51 AM
  2. Replies: 39
    Last Post: 08-07-2010, 04:59 AM
  3. Replies: 6
    Last Post: 05-13-2010, 12:52 PM
  4. Syil C6 CNC LATHE availabile Now.
    By syil in forum News Announcements
    Last Post: 07-22-2008, 01:14 PM
  5. syil c6 lathe help required
    By gglynn81 in forum Syil Products
    Last Post: 04-20-2008, 09:49 PM
