587,245 active members*
3,219 visitors online*
Results 1 to 2 of 2
    Dec 2009
    82
    Swivel Vise Question
    swivel Vise, probably a Shars or Enco.
    You cant rotate past about 50 degrees without removing the mounting bolts supplied with the vise.
    I just wanted to check before I cut the bolts off shorter, am I missing something?
    Thank you.
    Feb 2006
    7063
    You should be using T-nuts, with the bolts going in from the top, then the bolts should not interfere.
    Regards,
    Ray L.
  1. Swivel head for a R8 spindle on a bench top mill
    By lilricky2 in forum Benchtop Machines
    Last Post: 09-06-2007, 05:18 AM
  2. Haas mill multiple vise question (programming)
    By joesimmers in forum Haas Mills
    Last Post: 03-29-2007, 11:48 AM
  3. Home Made Vise Stop - For 6" Kurt Vise
    By widgitmaster in forum Bridgeport / Hardinge Mills
    Last Post: 12-15-2006, 03:49 PM
  4. Milling vise question
    By sierra4sport in forum MetalWork Discussion
    Last Post: 05-24-2006, 05:04 AM
  5. swivel leveling feet
    By DanOSB in forum Mechanical Calculations/Engineering Design
    Last Post: 09-20-2005, 02:37 PM
