587,168 active members*
3,220 visitors online*
    Feb 2010
    0
    Surfcam Lathe
    Hi every one, i need help with a post processor for a Haas lathe, Surfcam makes a post processor with tool description for mill, i would like to have one for lathe. It spells out what the tool dimensions are, can any one help me, thanks Jerry. Or how i can make one.
    Dec 2009
    80
    Hi, if you are using one of the Velocity versions you can run the "Post Menu Wizard" from Surfcam Tools in the start menu and add a new post for lathe. Under "S-post files" there is a lathe post for Haas SL series, maybe you can try with that one?
    did you ever get a post for you haas lathe. i could really use it if you did. thanks
  1. Surfcam for a lathe???????
    By CNChelp in forum Haas Mills
    Last Post: 05-30-2006, 11:55 AM
  2. Surfcam help
    By jamesr in forum Uncategorised CAM Discussion
    Last Post: 12-13-2005, 02:10 PM
  3. New surfcam
    By cadcam in forum Surfcam
    Last Post: 11-27-2004, 12:44 AM
