587,629 active members*
3,354 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Super easy question: Bipolar Parallel - Splice wires at the motor or at the driver?
Results 1 to 5 of 5
    Jun 2008
    1082
    I tried searching, but couldn't find an answer to this question. The title says it all, but let me explain further...
    I have some Keling "KL23H276-30-8B" steppers and some Gecko 203V drivers that I'd like to connect using bipolar parallel. I plan to run the motors at their rated current (~4.2 amps in bipolar parallel) at 48 volts.
    I bought some 18 AWG - 4 wire cable and am looking to run the cable about 1 to 2 feet.
    Should I run 2 of these cables between the motors and the drivers (in other words: should I run 8 - 18 AWG wires the whole distance)?
    OR
    Can I run just a single cable between the motors and the drivers (in other words: will 4 - 18 AWG wires be enough to transfer the required power between the motors and drivers)?
    I'd like to wire these motors the "best" way. But if it doesn't make any difference I'd prefer just a single cable between the geckos and the kelings.
    Thanks a bunch!
    Apr 2007
    8082
    I connected mine together at the motor leads and then ran four #18 wires to my Xylotex control board for the following reason:
    If you extend the eight wires to the control board before tying them together in bipolar parallel you would greatly increase the effective inductance of each coil that is wired in parallel. The long wires on each end of a given motor coil become additional inductors in series with each motor coil.
    In my case, the motor wires are around six feet long.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
    Jun 2008
    1082
    That sounds like some good thinking; thanks!
    Is 4.2 amps too much for 18 ga wire though?
    Oct 2008
    406
    Quote Originally Posted by Hirudin View Post
    According to this chart it should work (For a short run).
    http://wiki.xtronics.com/index.php/Wire-Gauge_Ampacity
    Jun 2008
    1082
    Cool!
    I searched a little, but the "Maximum Amps for Power Transmission" on charts like this...
    http://www.geistware.com/rcmodeling/...gage/index.htm
    scared me a little.
    I am relieved to see the explanation of the "conservative" numbers on the above site.
  1. Bipolar motor driver 6.5A ?
    By 0zeo in forum CNC Machine Related Electronics
    Last Post: 04-04-2011, 08:51 PM
  2. super easy to answer noob question m32
    By jordofmk in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-04-2008, 06:48 PM
  3. St 6208 Dmos Driver For Bipolar Stepper Motor
    By gcamlibel in forum CNC Machine Related Electronics
    Last Post: 01-25-2007, 06:37 AM
  4. cheapest driver for nema 17 bipolar stepper motor
    By cheater76c in forum Stepper Motors / Drives
    Last Post: 03-01-2006, 03:30 AM
  5. RQ: Bipolar stepper motor driver circuit
    By elektronchika in forum Stepper Motors / Drives
    Last Post: 12-22-2005, 12:29 AM
