587,089 active members*
2,850 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Suggestions for Cad/Cam Software
Results 1 to 5 of 5
Hybrid View
    Jul 2015
    3
    Hello, I am currently in search of cad/cam software. I am on a lower end budget since i am still going to school for manufacturing. I have recently purchased a 3 axis mill with fanuc controls. I am wondering what you guys would suggest ? I have been searching about Bobcad/cam and DolphinCad and have downloaded the demos. I am used to MasterCam and SolidWorks at school. Do any other hobbyist have any suggestions? Thanks, Jake.
    If you are just wanting to do 2.5D stuff then GSimple is FREE.
    I use it to produce quite complex parts for radio control cars. It does most things, including thread milling, although I have to wrestle with the G-Code to make use of the thread mills that I have.
    It does not work with 3D modelling software. For complex shapes, I have to draw my cutter paths in 2D and import them as .dxf files. I then let GSimple create an engraving path, which I then extrude in Z by doing multiple copy and paste on the text file.
    But for hobby work it does the trick.
    Apr 2015
    11
    Re: Suggestions for Cad/Cam Software
    HI. I used MasterCam too not only at school). What can I say? I'm glad because of the comfortable online support and so pleasant community. About Bobcad/cam and DolphinCad I even don't know. If you are just wanting to do 2.5D stuff then GSimple is FREE? Good news!
    35538
    Autodesk Fusion 360, which you can get for free.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jan 2014
    37
    Try FILOU NC12, it has some CAD functions and is verry strong in CAM, You can get a highly discounted student Version.
  1. Software Suggestions for DIY CNC
    By BaySigns in forum Signmaking Topics
    Last Post: 04-08-2011, 03:53 PM
  2. CAD CAM Software suggestions
    By jimmy996 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-30-2010, 03:01 PM
  3. Would like CAM Software Suggestions
    By Ranger79 in forum Uncategorised CAM Discussion
    Last Post: 01-27-2010, 11:42 PM
  4. Looking for new CAD/CAM software, suggestions....?
    By automan9482 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-08-2008, 01:48 PM
  5. Suggestions for CNC software
    By AccuDave in forum Open Source CNC Machine Designs
    Last Post: 04-14-2006, 03:47 AM
