587,558 active members*
3,513 visitors online*
Results 1 to 6 of 6
    Sep 2014
    21
    Question Sudden reduction in power
    The basic problem I am having is that all of a sudden my machine is not able to cut through material it used to.
    I've checked, cleaned and realigned everything multiple times, and I'm sure it's all lined up as best as I can. Yet it still seems like I've just suddenly lost a large percentage of the laser's power.
    It is an 80W laser (redsail machine), and I'm only just getting through 4.5mm acrylic at 100% power, 10mm/sec speed.
    I've also noticed the reduction in power from left side to right side of the bed more noticeable than before.
    I'm concerned the tube has damage somehow? Or is it likely I'm just not getting the mirrors aligned? Or something else altogether?
    Any suggestions on what I should be looking at would be greatly appreciated!
    Jan 2008
    940
    Re: Sudden reduction in power
    Quote Originally Posted by thefitz View Post
    It sounds like you over powered your tube You need to check your power on an ammeter some power supplies will send way to much power to the tube. On mine I have to run it at 90% power and that is equal to 100% power that my tube can handle
    Sep 2014
    21
    Before the drop in power, I could cut the same material at 55% power. I'm not keen at running it at such high power atm, it is just the only way I can get the cut to work.
    Will keep investigating...
    Dear,
    How long have been using the laser tube? If the laser tube is within warranty period, you should talk with the seller.
    Thank you.
    Anna
    Anna
    Peak Glass Inc
    [email protected]
    [email protected]
    www.peakofglass.com
    4635 Rue Fairway Lachine
    QC H8T 1B7
    514-409-7176
    https://www.facebook.com/Lasertube
    laser tube
    Dear,
    Thank you.
    Anna
    Peak Glass Inc
    [email protected]
    [email protected]
    www.peakofglass.com
    QC H8T 1B7
    514-409-7176
    Jul 2015
    55
    Have you checked the mirror alignment ? (By removing the lens and checking even the final mirror)
    Does you machine have a current meter which shows the milli amps going to the tube ?
    If the mirrors are in alignment, and the lenses and mirrors are clean and undamaged, then that just leaves the power supply and laser tube.
    If you have a current meter and your tube is getting the correct current, then the problem is likely to be the tube.
  1. sudden loss of cutting power on 90W Reci
    By TSHobbies in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-13-2015, 03:38 AM
  2. Need Help JQ 1290 laser down on power all of a sudden
    By Dave Matthews in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-09-2014, 06:09 PM
  3. sudden G540 issue
    By CS900 in forum Gecko Drives
    Last Post: 08-25-2013, 09:38 PM
  4. Mill Conversion Servo Power and Gear Reduction
    By aubreyj in forum Benchtop Machines
    Last Post: 05-14-2012, 05:17 PM
  5. Sudden loss of motor power VSD-A v2
    By ftec in forum CNC Machine Related Electronics
    Last Post: 10-11-2010, 09:48 PM
