i am verry happy with the VSD-E /x Drives which i use in My Retrofit project i am about to Finnish soon (some pics here http://www.tkamsker.at:8080/web/pub/analyse on my old homepage)
the Z Axis has around 350kg and has an Brake
in Normal mode the brake works as it should
But if i switch off the 160V to simulate error the Brake is still open only if i switch off the 12V the brake is closed.
I was under the impression that if there is an under voltage (or over voltage and other errors like the manual says ) the brake should be applied.
i did configure that error reset works if power is back to ok
Is there anyone who has an hint for me because this really blocks my finnishing ,..
i did play for more than 6 weeks to get the configuration the way i have it right now ,..
so sometimes the moving masses make the drive stall and in that case i need the brake working
so i am happy for any input or advice or sample what i could do
thx
thomas
