587,215 active members*
3,864 visitors online*
Results 1 to 7 of 7
    Mar 2004
    16
    Stepperworld sp-3
    Hello, I have a home brew cnc router that worked fine till just recently. The z axis will not move down while running a program. The axis moves with the jog keys ok. I have noticed there is no holding torque on the motor while a program is running. Hit the stop button in master5 and the motor holds. I swaped the z and y axis and the problem moved so I think I can rule out the motor. Any ideas as to where to begin? Here is a sample file I was using. Thanks in advance.
    Attached Files Attached Files
    Jun 2008
    614
    By this you mean the problem occurred on the Y axis after you swapped them and the Z axis was then working fine?
    and what exactly did you swap on them? the motors, controllers, etc...?
    http://www.g0704.blogspot.com/
    Mar 2004
    16
    I swapped the wiring from the sp-3 to the motors. After doing this then z had holding torque and y did not.
    Jun 2008
    614
    SP-3 is a type of controller? forgive me Im pretty new to steppers, I run a CNC machining shop for toyota, we use all Fanuc servo gear...
    Mar 2004
    16
    sp-3 is a stepper controller from stepperworld.com . Very low end but they do have some better products.
    May 2007
    380
    If the stepper driver was bad, you would not be able to jog the axis. My thoughts are possible software corruption. Stepperworld has a utility program that lets you run up to 3 axis either single steps or steady running in either direction and varying speeds.
    John
    Jun 2008
    614
    Im sure you have already done all the normal stuff..(checking cables, connections, etc...)
  1. stepperworld drivers
    By wjfiles in forum Stepper Motors / Drives
    Last Post: 06-04-2006, 05:03 PM
  2. Xylotex or stepperworld (or something else)?
    By jdbaker in forum Stepper Motors / Drives
    Last Post: 12-16-2005, 05:34 PM
  3. help with stepperworld sp3/ht
    By mmech in forum CNC Machine Related Electronics
    Last Post: 10-24-2005, 07:42 PM
  4. Stepperworld fet 3 question
    By Billw in forum Stepper Motors / Drives
    Last Post: 07-18-2005, 07:03 AM
  5. Stepperworld boards
    By itsme in forum Stepper Motors / Drives
    Last Post: 02-09-2005, 02:03 PM
