587,482 active members*
3,137 visitors online*
Results 1 to 7 of 7
    Nov 2003
    314
    Stepper Question
    Hi Guys
    New to this excellent forum, Just prurchase the MDF and will be starting cutting it up today.
    On the motor end Biplor and unipolar what is best.
    I have the chance of getting a:
    VEXTA STEPPER MOTOR PART No PK266-02B DC 2A 1.8 OHM . 2 PHASE STEPPER MOTOR. DOUBLE SHAFT TYPE. 56.4MM SQUARE. 1/4" SHAFT.
    It is new and is cheap, is two phase bipolar ?
    On Cranky's web site hes says to look out for brands like Vexta so I thought this would be suitable.
    Do all the three motors have to be identical ? I know they all would have to be either biplor or unipolar but thats all.
    Thanks guys
    2139
    Unipolar motors can be used on a bipolar drive, but bipolar motors can't be used on a unipolar drive.
    If you are going to use a bipolar drive, either will do, if you go unipolar drive, you need unipolar motors.
    You can use 3 different motors, but 3 identical motors makes a neater install...It's what ever makes you happy.
    Eric
    I wish it wouldn't crash.
    Nov 2003
    314
    Thanks for the reply
    Is the motor above suitable for something like your first machine ?
    Also I have seen 3 of the following for sale.
    NEMA 42, 2 Stack, Sanyo Denki H Series High Performance, rare earth magnet, stepper motor
    Sanyo Part No: 103H89222-5421
    200 full steps per rev (1.8 degrees per full step); 2.5 Volts, 6 Amps per phase; Holding torque 120 kg.cm (11.8 Nm, 1670 oz.in); Body diameter 106.4mm (4.2 ins); Body length 163.3mm (6.43 ins); 4 lead bipolar motor - can ONLY be used with bipolar stepper drivers.
    I think these won't be as cheap though, but are they any good for the purpose.
    I don't know anything about steppers - YET !
    Nov 2003
    314
    OK seems the Nema at 6A is too much 1 - 2A for a small machine seems about right.
    Learning all the time
    Thanks Balsaman for your PM
    2139
    Nov 2003
    314
    Vexta stepper
    I have been offered two brand new Vexta PK266-02B steppers rated at 2A 127 ozins which seems very good the spec says 3.6v
    but when I look at the product page on the Oriental motor company site it shows 24v and 36v on the graph.
    I am a bit confussed.
    Oriental link
    http://www.orientalmotor.co.jp/cgi-b...frameSize=56.4
    Anybody have the web site of Nema type motors
    35538
    Those are the voltages the motors are being run at to get the results shown in the graph.
    Gerry
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. Stepper Question
    By ignatz in forum Stepper Motors / Drives
    Last Post: 04-23-2005, 10:26 AM
  2. Stepper drive question
    By Dman in forum DIY CNC Router Table Machines
    Last Post: 01-10-2005, 03:55 AM
  3. Stepper Motor Question
    By bcromwell in forum CNC Machine Related Electronics
    Last Post: 08-31-2004, 08:42 PM
  4. Stepper motor spec' source & question
    By Damachine in forum DIY CNC Router Table Machines
    Last Post: 04-06-2004, 07:01 PM
  5. AC stepper motor question
    By flybynight in forum CNC Machine Related Electronics
    Last Post: 01-21-2004, 12:47 AM
