There are other factors that affect torque other than just current, voltage, current and stack length for a couple. The largest torque on a stepper is the maximum holding torque which occurs when the motor is stationary, so I would imagine if you energize the motor at the rated voltage and current to hold it stationary, you could measure the holding torque with a pulley attatched to the shaft with a cord around the pulley and a spring balance to measure the point at which it releases and calculate the oz-in figure as is used in other servo torque measuring methods.
Al
Albert E.
