587,698 active members*
3,362 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Stepper Motor is switching directions randomly
    Jan 2011
    0
    Exclamation Stepper Motor is switching directions randomly
    Ok, we've got our Larken conversion to USB CNC setup and running, cut some letters the other day perfectly using vcarve pro, now where having some issues with Z that wasn't displaying the other day.
    Z upon either up or down action seems to randomly pick it's direction. Repeated manual jog will cause the motor to switch directions it seems.
    Is this a reason to replace the stepper or should I be looking at another issue? If another issue, some pointers would be greatly helpful.
    May 2007
    54
    it my days fixing various machines this either means the driver is weak or the stepper is bad. usually was the driver
    Sent from my GT-P1000 using Tapatalk
    Jan 2011
    0
    Hrmmmm
    How would I check?
  1. Stepper changes directions and has play in shaft
    By Scheer in forum Stepper Motors / Drives
    Last Post: 11-13-2010, 07:57 PM
  2. Integrated stepper motor? with built-in stepper motor driver
    By uirobot in forum News Announcements
    Last Post: 06-07-2010, 09:59 AM
  3. Z axis randomly plunging
    By Don-in-Japan in forum Benchtop Machines
    Last Post: 05-31-2009, 07:58 PM
  4. motor chatter when changing directions
    By chevdrgtrk in forum Servo Motors / Drives
    Last Post: 03-24-2008, 12:25 AM
  5. Beltdrive-stepper motor-stepper motor driver
    By Georg in forum Stepper Motors / Drives
    Last Post: 10-16-2007, 10:56 PM
