587,473 active members*
3,530 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > Stepper motor sizes for 7x12 with G540.
Results 1 to 13 of 13
    Aug 2009
    986
    I've looked through other build threads, and what I have yet to find is good information about the correct size stepper motors to use with mini-lathe.
    I've got a G540 control box ready to go, so I'm limited to its 48 volts, 3.5 amps.
    I can put the best possible stepper on the Z, which is a Keling KL23H2100-35-4B. This is a 381 oz/in motor that works best at the volts and amps of the G540. The problem is, it's way too big to work on the X axis. I need something smaller and lighter for that location.
    What are you guys using on your mini-lathes? I'd like to hear torque ratings and dimensions of the motor, specifically, the length.
    Frederic
    Jan 2010
    2141
    I'm interested in seeing this also.
    Seems to me that I remember one conversion that mounted the X stepper below the X axis, reversing it so that the shaft pointed away from the ways, and using a 1:1 timing belt drive, as a way of reducing the distance that the motor stuck out (but I'll have to look for the thread).
    OK, I found the thread that I was thinking about, here are two of the posts from it:
    http://www.cnczone.com/forums/623750-post1.html
    and
    http://www.cnczone.com/forums/625969-post13.html
    His x axis motor looks pretty big physically, but of course that doesn't mean that he needed all of that torque for the application.
    Aug 2011
    0
    This is copied out of a Mini Lathe CNC conversion PDF i have.
    " Nema 23 Stepper motors near or greater than 200oz-in"
    That set up uses the stock lead screws also. So if your switching out to balls screws you could go below 200oz a bit.
    Nov 2008
    37
    Mini Lathe CNC Conversion PDF? I'd like to see that, can you tell me where you got it from?
    Rich
    Aug 2011
    0
    Quote Originally Posted by rich_cree View Post
    Rich
    Here you go.
    Nov 2007
    616
    I used KL23H276-30-8B from keling, and all the dimensions you could possibly want are given on spec sheets on their website. These motors are 282 oz motors. They are not as efficient or perfectly matched as the 381 oz motors, they will run at a slightly lower power, but they were PLENTY powerful for a 7x lathe, and ran flawlessly on a G540 (my conversion is the one doorknob posted links to. FULL THREAD HERE ). Also, an added bonus, they require no current limiting resistor on the wiring.
    Personally, I don't understand the logic of using mis-matched motors on Z and X simply because you can fit a larger motor on Z. I also feel that 381 oz motors are serious overkill on this size lathe. My conversion was somewhat light-duty, not utilizing ball screws. The motors I used were more than capable of exceeding the torque the lathe was built for.
    <a href="http://www.cnczone.com/forums/mini-lathe/82871-7-x-10-project-started.html" target="_blank">7X10 Lathe conversion</a>
    <a href="http://www.cnczone.com/forums/open-source-cnc-machine-designs/335846-cnc.html" target="_blank">Custom X-Carve router</a>
    <a href="http://www.linkedin.com/in/tooldesign" target="_blank">LinkedIn</a>
    Aug 2009
    986
    Quote Originally Posted by blades View Post
    Thanks for the feedback on your motor choice.
    The logic of the mis-matched motors is just that of economy. I have a 381 oz in motor lying around unused, so it made sense to use it on the Z axis.
    The reason I wanted smaller on the X is because the X motor sticks out and moves the center of gravity of the saddle. It's my belief that the CG should be on top of the ways.
    I can always use a counterweight, but I like the way that you did yours. By slinging the motor down under, you likely kept the center of mass between the ways.
    Frederic
    Aug 2009
    986
    blank post
    Mar 2005
    335
    on mine i used a 380 motor on z and 300ish on the x.
    x was lead screwed and z had a 1605 ballscrew on it.
    Nov 2009
    724
    How about this one stepper motor Its about .75" shorter than the 381's
    and its a perfect match for the G540, and the BEST thing is its US MADE!!!
    JTCUSTOMS
    "It is only when they go wrong that machines remind you how powerful they are."
    Clive James
    Nov 2007
    616
    Quote Originally Posted by TXFred View Post
    Frederic
    That was my feeling exactly, I wanted to keep the mass under the saddle, and I was also wanting to keep the footprint no larger than the original lathe (no motors sticking out anywhere).
    Mar 2005
    335
    my recommendation would be to extend the cross slide by a 30-40mm so you can how tools with a little more projection and maintain the capacity of the machine this will gain you some more room for the stepper to be under slung. I did this on mine with in line motor mounting and did not have any issue with binding.
    I would recommend getting rid of the compound slide and original tool post as this is where most of the problems occur in this machine.
    7 x 12 lathe tool post modification - YouTube
    With the mods i can hold +/-30um with out really trying.
    Now it is a really good machine!
    Aug 2009
    986
    I ordered those same motors. I haven't decided exactly how I'm going to mount them, but I suspect that I'll be copying your design for the X axis. For Z, I need something more rigid than your design, so will probably set up a ballscrew in place of the current lead screw.
    Frederic
  1. NEW NEMA34 Stepper Motor with G540 driver kit
    By automationtechinc in forum Automation Technology Products
    Last Post: 12-11-2010, 01:29 AM
  2. 7x12 Motor Controller Problem
    By Nsomnia in forum Mini Lathe
    Last Post: 09-24-2010, 02:52 AM
  3. G540 Stepper motor spec
    By port_huon in forum Gecko Drives
    Last Post: 03-08-2009, 05:20 PM
  4. stepper sizes
    By DDM in forum DIY CNC Router Table Machines
    Last Post: 11-30-2003, 02:35 AM
