587,252 active members*
3,302 visitors online*
Results 1 to 2 of 2
    Jun 2009
    38
    Stepper motor noise
    I just purchased a Light Machines Spectra mill 0200 for $150. I am running Ubuntu and EMC2 (Both of them recently downloaded, so latest versions). I got the controller talking with the mill so it will jog in the correct directions, but there is a loud squeel or high pitched whine coming from the stepper motors when I activate EMC2. If I just open up EMC2 and have the controller box on, the stepper motors are rigid, but they don't squeel. If I hit the red button with the white x on it in the upper left corner then the squeeling starts. I hit the button immediately to the right of that and then I can manually jog the machine. The whole time that the machine is moving it will squeel until I hit the red button again, but then I can't run any G-code. It's driving me crazy. Do you guys have any hints as to how to fix this problem. I used this parallel port adapter to connect the computer to the controller.
    Thank you for your help!
    http://build.spaceopera.org/site/spe...ter/index.html
    Feb 2010
    0
    A jab in the dark: Could the software be setup to do half steps and the motor unable to handle halfies?
    Wen I was young, I spent most of my money on fast women, slow horses, and cheap booze. The rest of it I just wasted.
  1. Stepper Motor doesn't spin but makes noise
    By Finder in forum Stepper Motors / Drives
    Last Post: 07-21-2016, 03:23 AM
  2. Stepper motor noise?
    By Drools in forum CNC Machine Related Electronics
    Last Post: 02-16-2013, 01:34 PM
  3. Stepper motor noise
    By dmparrott in forum CNC Machine Related Electronics
    Last Post: 10-03-2007, 04:35 PM
  4. MACH3 and noise from stepper motor
    By timeout555 in forum Mach Software (ArtSoft software)
    Last Post: 03-01-2007, 04:39 AM
  5. stepper setup, Electrical noise ?
    By veteq in forum Stepper Motors / Drives
    Last Post: 02-08-2007, 05:31 AM
