587,143 active members*
3,990 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > Stepper motor- increasing speed rotation
    Oct 2010
    17
    Hi guys, My spec's are
    Motor
    Nema 23 425oz model 23HS2430 3A
    1.8 step angle
    3 amp
    2.1 phase resistance
    9 phase induct
    4 wire
    Driver
    DM542A
    128 microstep
    1 amp to 4.2 amp
    18 to 50 VDC
    I am trying to increase my speed rotation. I get only 80rpm for now. What should i do to increase my rotation speed?
    Jan 2010
    2141
    Re: Stepper motor- increasing speed rotation
    How much voltage are you using on it?
    Your motor has a relatively high inductance, which will limit the maximum speed that you can get from it, especially because your driver is limited to only 50 volts maximum.
    What microstep setting are you using?
    When you say that you are getting 80rpm, are you driving a CNC machine axis with the motor (and if so, are you driving a leadscrew or belt pulley), or are you using it in a different application?
    Aug 2006
    2758
    Since you are saying you are using 1/128 micro-step mode:
    2x speed increase ...............use 1/64 micro-step mode
    4x speed increase ..............use 1/32 micro-step mode
    8x speed increase ............. use 1/16 micro-step mode
    I have the same motors and they have being tested at more than 1800 rpm with a 48 Vdc power supply using Mardus-Kreutz drives ( > 90 ipm with 20 tpi leadscrews).
    kreutz
  1. Increasing Bridgeport spindle speed.
    By tonyfoale in forum Bridgeport / Hardinge Mills
    Last Post: 08-02-2014, 07:45 AM
  2. Rotation Change to stepper Motor with driver EM705
    By marcoabril in forum Stepper Motors / Drives
    Last Post: 07-29-2014, 03:07 AM
  3. Stepper motor - how many mm per one rotation
    By brunoalokacija in forum Stepper Motors / Drives
    Last Post: 08-25-2013, 04:19 AM
  4. Increasing speed on Multicam/Hypertherm unit
    By chevelless502 in forum Hypertherm Plasma
    Last Post: 02-08-2012, 01:26 PM
  5. Increasing spindle speed
    By RP Designs in forum Uncategorised MetalWorking Machines
    Last Post: 05-07-2009, 06:57 PM
