587,226 active members*
3,159 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Stepper motor : FL60STH86-3008BF
Results 1 to 5 of 5
    May 2007
    2
    Hi all,
    I am new to this site, and my project is to convert a milling machine ( BF20L )
    whith this stepper motor :FL60STH86-3008BF
    Could you tell me if this stepper is a good choice for this job ?
    (Power in bipolar Parallel mode whith MSD542 microstepping driver -4.2A 35V)
    Step Angle 1.8 Deg
    Step Angle Accuracy 5% (full step, no load)
    Resistance Accuracy 10%
    Inductance Accuracy 20%
    Temperature Rise 80OCMax.(rated current,2 phase on)
    Ambient Temperature -20OC~+50OC
    Insulation Resistance 100M Min. ,500VDC
    Dielectric Strength 500VAC for one minute
    Shaft Radial Play 0.02Max. (450 g-load) Shaft
    Axial Play 0.08Max. (450 g-load) Max.
    radial force 75N (20mm from the flange)
    Max. axial force 15N
    Wiring - Voltage - Current Phase - Inductance - Inductance - Holding Torque
    Unipolar : 3.9 V - 3 A - 3.2 mH - 1.3 Ohm - 2.15 Nm
    Bipolar (P) :2.73 V - 4.2 A - 3.2 mH - 0.65 Ohm - 3 Nm
    Bipolar (S) : 5.46 V - 2.1 A - 12.8 mH - 2.6 Ohm - 3 Nm
    thanks for your comments, and sorry for my bad english.
    Mar 2005
    1673
    Hi and welcome to the zone,
    Click on the link and have a read through the thread; it may give you the information you need. http://www.cnczone.com/forums/showthread.php?t=15538 . If you don’t find anything give a shout back here.
    John
    Jan 2006
    245
    This motor is an the replacement to the FL60STH-2008BF that was a good motor, but suffered due to the high inductance.
    We had this motor wound specifically to work with the MSD542 driver and the parallel phase current is 4.2A and the inductance is a lot lower than the original motor.
    Saying that to get the best from the motor you will need to give it more volts.
    Have a look at the torque curve in the datasheet, it really shows how important the higher votage is.
    http://www.motioncontrolproducts.com/fl60sth86.pdf
    Quote Originally Posted by sebastien-89 View Post
    Hi all,
    Step Angle 1.8 Deg
    Motion Control Products Ltd
    www.motioncontrolproducts.co.uk
    May 2007
    2
    Is the msd542 with 35v is enought to power the stepper at high voltage, or should i use more voltage 50V, 60V ?
    What is the maximum that i can use whith this stepper ?
    Thanks.
    Jan 2006
    245
    35-40V is the best foltage to use.
    The max voltage of the driver is 50V, so having the foltage at 40V gives you some head room for BEMF.
    Thanks.
  1. Stepper motor
    By toneV8 in forum Stepper Motors / Drives
    Last Post: 08-01-2012, 04:26 PM
  2. Need Help With Stepper Motor
    By simplicity in forum Stepper Motors / Drives
    Last Post: 04-27-2007, 03:41 PM
  3. servos motor controled by stepper motor driver?
    By mike10 in forum Servo Motors / Drives
    Last Post: 01-04-2005, 12:05 AM
  4. Which stepper motor should I buy
    By Graham S in forum FAQ of DIY CNC Machine Building
    Last Post: 08-27-2004, 11:58 AM
  5. stepper motor help
    By muzleldr in forum CNC Machine Related Electronics
    Last Post: 06-10-2003, 08:15 PM
