587,875 active members*
3,422 visitors online*
IndustryArena Forum > Hobby Projects > Hobby Discussion > Stepper controlled coil winder
Results 1 to 6 of 6
    Jan 2007
    16
    Hi there
    I built a first prototype of stepper controlled coil winder using the following architecture :
    • PC interface in MS Excel
    • VBA code to do the maths according to wire gauges, # turns etc
    • Mscomm32.ocx to send communication to COM4 port
    • FTI USBMOD4 device (http://www.elexol.com) to use USB interface
    • Bit 0 pilots the coil stepper driver: Qasar 3179 unipolar driver (http://www.quasarelectronics.com) . Current regulation (4.5A) uses a simple and old-fashioned power resistor. The motor is 86HY62DE04 from http://www.3xmotor.com
    • Bit 1 pilots the wire guide stepper driver: Qasar 3158 bipolar driver. The motor small motor has been salvaged from an old fax machine.
    The system works BUT in my opinion the rotation is not smooth and regular. Sometimes the motor groans and waits. This is not satisfactory and I am seeking for advices.
    In my opinion flaws could come from
    • VBA + Mscomm32.ocx: not reliable enough?
    • USBMOD4 interface: tuning of capacitors between RXE and RD?
    • Qasar drivers?
    • Motor Current regulation?
    Can anyone of you give advices, feedback, hints?
    MANY THANKS
    Guy
    Jun 2003
    3312
    Maybe a combination of issues. USB has high latency, so you could possibly be seeing a variance of pulse timing. Second issue would be the full step Qasar driver, you would gain by going to at least half step, if not quarter or eighth. There is a lot of difference in motor smoothness between full and half step, and each subsequent microstep size.
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Guy
    The VBA is very unreliable when it comes to maintaining timing.
    The USB has a built in 1 ms latency. That's the time between when you tell it to send data till it actually gets sent.
    I had to add processor on USB end to get sweet step signals.
    Dennis
    http://www.super-tech.com
    Jan 2007
    16
    Thanks Phil and Dennis.
    I will then reconsider my architecture :-)
    Thanks again,
    Guy
    hey,
    just curious if you have any pictures of the coiler. sounds like we're in the same field, I'm gonna be working on one of these too.... some day.
    Hope to hear from you soon,
    Jesse
    Mar 2006
    2712
    I don't know how practical this would be. Kollmorgen (Danaher) has a motor type called "servo-disc". They claim zero cogging at 1 rev. per DAY. Some are in kitmotor form.
    Dick Z
    DZASTR
  1. Filament Winder
    By RotorRouter in forum Open Source Controller Boards
    Last Post: 03-31-2014, 05:14 PM
  2. Computerized Coil Winder Build in Progress
    By vacpress in forum Musical Instrument Design and Construction
    Last Post: 05-10-2008, 01:20 PM
  3. cnc controlled mandrel bender controlled by mach3
    By timmyb199 in forum Bending, Forging, Extrusion...
    Last Post: 05-31-2007, 12:35 AM
  4. Transformer Coil Winder
    By cjenrick in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-17-2006, 03:43 PM
  5. Coil Winder
    By itsme in forum I.C. Engines
    Last Post: 08-25-2006, 07:12 PM
