Hi all,
I have the opportunity to buy a StepSyn 103H7123-1740 stepper motor that is within my price range.
The specs are as follows:
SANYO DENKI STEP-SYN STEPPING MOTOR
4 AMPS DC
1.8 DEGREES PER REVOLUTION
NEMA 23
1/4" X 3/4" SHAFT
4 WIRE BIPOLAR
0.33 OHMS
1.3 VOLTS
I currently have 2 StepSyn motors with the numbers 103H7123-1742
I would like to have 3 matched motors.
Is the motor I have the opportunity to buy a close enough match to the two I have now? I don't have the exact specs on the motors I have.
I read somewhere the the part numbers change based on the use of the motors (for this manufacturer).
Thanks in advance for the help.
