587,087 active members*
2,904 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Steel workbench on casters - how to provide leveling?
    Mar 2006
    103
    So I'm welding together super heavy duty workbench made from steel square tubing and then placing 1/2" steel plate on top to provide a nice level surface (I believe the steel vendor quoted 1/8" flatness over 10ft).
    However I would like to have this on casters and I have found some casters from colson that I would like to use but due to some variations on the frame of the table it doesn't sit flat (some wobble).
    What is the recommended way to use casters and allow leveling?
    I was thinking about making a large male thread (1"-12 ) or something like that and welding that to the caster and then putting the female thread on the bottom of the workbench legs. That way I can adjust the height of the caster by simply threading more or less.
    Any ideas - perhaps an easier approach?
    cheers,
    Paul
    Aug 2004
    2849
    check out accesscasters.com for leveling casters.
    zambus.com also has leveling casters, but no prices.
    Paul
    Jul 2005
    12177
    Put some levelling screws on that not only level the table but lift it up off the casters when it is in use. This not only stops the table rolling away when you lean on it, it also prevents flat spots forming on the casters if you are using plastic wheels that are stationary for a long time with a load on them.
  1. Best Workbench Casters. Period!
    By MRM RCModels in forum Benchtop Machines
    Last Post: 02-23-2012, 08:04 PM
  2. New Machine Casters
    By PhillyCyberJoe in forum Joes CNC Model 2006
    Last Post: 03-14-2009, 02:43 AM
  3. air casters
    By jack clay in forum Mechanical Calculations/Engineering Design
    Last Post: 05-01-2007, 04:51 AM
  4. V groove casters
    By AustinT in forum Linear and Rotary Motion
    Last Post: 12-25-2005, 06:44 AM
  5. Super deal on steel workbench w/casters for $99
    By CNCPlastic in forum Uncategorised MetalWorking Machines
    Last Post: 10-26-2004, 09:21 PM
