587,773 active members*
3,403 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Starting G0704 with EK's Kit
Page 1 of 2 12
Results 1 to 20 of 35
    Have been following all the G0704 threads. Great info from Hoss and EK. Thanks again.
    I ordered G0704 on 5/13, initial ship date was 6/11, then it was delayed until today, I mean TODAY, i am very excited. Once I have the machine I will post pictures.
    EK's conversion kit was ordered 5/15. And received ball screws on 7/11, machined parts came in 7/12. I understand a lot of people are planning to order the EK kit.
    Here are some pictures:
    Attached Thumbnails Attached Thumbnails Conversion Kit (1).jpg   Conversion Kit (19).jpg   Conversion Kit (20).jpg   Conversion Kit (21).jpg
    Conversion Kit (22).jpg   Conversion Kit (2).jpg   Conversion Kit (3).jpg   Conversion Kit (4).jpg
    Conversion Kit (5).jpg   Conversion Kit (6).jpg   Conversion Kit (8).jpg   Conversion Kit (9).jpg
    Conversion Kit (10).jpg   Conversion Kit (11).jpg   Conversion Kit (12).jpg   Conversion Kit (13).jpg
    Mar 2009
    97
    nice kit - i am doing the same
    I got my kit a couple weeks ago - also from EK. Have to say i am very pleased - though the standoffs for my z-axis motor mount are a still short - no issue though - i have a lathe so I can make new ones.
    Looks like you are going for the front mount on the y-axis? I am working on finding a place to get the mill modifications done - lots to do - saddle table and column and unfortunately my machining class is over so no more access to the bridgeport. I need two mills!!!!
    What about your control box - did you get everything from Kelinginc? That is the part i am the most concerned about - electronics are a BIG mystery for me!!!
    Jan 2010
    2141
    Who or what is EK?
    Apr 2005
    403
    Have not been on the zone for a while, but there are some good reference materials floating around on the zone such as linear power supply tutorial, gecko has a good info paper on drives and check into breakout boards. The Mach III manual also is a good reference.
    Cant wait to see the build.
    Good luck!!
    Ron
    Nov 2009
    3
    What is EK?
    Feb 2007
    4553
    Post
    Ledinc & Doorknob,
    "Ek" is Ellik,
    He is the gentleman that makes the conversion kit and is a member of the CNCZone.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    I have the electronics from oversea. As our company oversea purchasing bought these items for me, and I pay no shipping, which is a good deal.
    I will post more pictures on electronics.
    Here is the machine before anything is done.
    Attached Thumbnails Attached Thumbnails before1 (1).jpg   before1 (3).jpg   before1 (2).jpg
    I started to take everything apart.
    Attached Thumbnails Attached Thumbnails disassemble (1).jpg   disassemble (2).jpg   disassemble (3).jpg   disassemble (4).jpg
    working on Z now. Sorry for the picture. I try not to use flash.
    Z pictures.
    Attached Thumbnails Attached Thumbnails Z (1).jpg   Z (2).jpg   Z (3).jpg   Z (4).jpg
    Y Ball Screw not fit
    I am trying to put the Y ball screw in. But it will not fit. Maybe I am just tired.
    And I do not want to take the nut off the screw. This is becoming a puzzle for me.
    HELP NEEDED. I am pulling hair now.
    Attached Thumbnails Attached Thumbnails Y Ball Screw not fitting (1).jpg   Y Ball Screw not fitting (2).jpg   Y Ball Screw not fitting (3).jpg
    Mar 2005
    305
    I had to thread the ball nut on the screw after the screw as in place. You may need to do it that way.
    Thanks rcazwillis,
    I took the nut out and put it back.
    Took me 1 hour, and 3 extra ball. This is the best I can get.
    The first several tries, I end up with 7 or 10+ balls. And I think 3 extra ball is probably the best I can do.
    Next week, some of the parts need to be modified.
    Jan 2006
    628
    One trick I've used for removing ball nuts from the screw is to find a dowel or tube of some sort that is just a bit undersized from the screw. You butt this up to the end of the screw and when you twist off the ball nut the dowel keeps the bearings from coming out.
    Wish I had a better explanation, but that is one technique.
    Steve
    Feb 2010
    0
    You are definately going to want to not make that so wide, or instruct to cut a hole. rethreading inside the base is not optimal..well at least it wasnt in my rf45
    Jan 2006
    123
    For those wondering about the EK kit here is a link for the build and a link for the kit.
    Build looks good so far. I know when Ellik did my mill and Blair's mill there were slight differences in the castings.
    Oct 2007
    155
    I've been away the last week or so and just noticed this thread.
    I am afraid you have to take the ball nut off to insert the screw. For those with a rear mounted stepper the screw can be installed without doing so, back end first then front.
    Nice pictures, thanks.
    EK
    Quote Originally Posted by bensonave View Post
    Oct 2007
    155
    By inserting the bronze bushing, that is on the stock Z lead screw, between the thrust bearing and the screw you can probably use the motor standoffs. I should make them longer though. Thanks for the feedback.
    EK
    Quote Originally Posted by dsdmax View Post
    Oct 2007
    155
    Thanks for clearing that up Jeff.
    EK.
    Quote Originally Posted by jalessi View Post
    Ledinc & Doorknob,
    "Ek" is Ellik,
    Jeff...
Page 1 of 2 12
  1. Hoss's G0704
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-25-2016, 12:48 AM
  2. New grizzly G0704
    By madtownrob in forum Benchtop Machines
    Last Post: 02-05-2013, 05:59 PM
  3. G0704 Conversion
    By rcazwillis in forum Benchtop Machines
    Last Post: 07-17-2011, 03:27 PM
  4. Grizzly G0704 Build
    By nocashvalue in forum Benchtop Machines
    Last Post: 11-16-2010, 04:33 AM
  5. g0704 - first mill - questions ....
    By dsdmax in forum Benchtop Machines
    Last Post: 03-28-2010, 09:32 PM
