587,083 active members*
2,672 visitors online*
Results 1 to 9 of 9
Hybrid View
    Feb 2022
    1
    Stainless Steel 316 VS 316L Difference
    Hello,
    316 vs 316L Stainless Steel what's the difference?
    Thank you.
    Jan 2005
    15362
    Re: Stainless Steel 316 VS 316L Difference
    Quote Originally Posted by VisionAlloys101 View Post
    Hello,
    Thank you.
    The L = Low Carbon so not much difference apart from that, the L is better for welding
    Mactec54
    May 2022
    4
    and what is the difference between these two and 304?
    Jan 2005
    15362
    Quote Originally Posted by langoshin View Post
    Thats a very open question, if you do a Google search you will find what you need
    Here is some information on the (2) material grades
    https://www.rocheindustry.com/304-vs...el_differences
    Mactec54
    Mar 2008
    683
    304 is a pain to machine, in my opinion. It work hardens as you cut it and if you lighten up on the cuts it just turns nasty after a while. in my experience 304 is almost always used in food grade applications and 316 in mechanical applications.
    May 2022
    4
    thanks guys
    cookie clicker
    Sep 2022
    2
    The main difference between 316 vs 316L stainless steel is that 316L has a lower carbon content. This is because 316L has less carbon in it than 316. This makes it more resistant to corrosion.
    The other main difference between 316 vs 316L stainless steel is that 316L is a more affordable option. This is because it has less carbon in it, which makes it less expensive to produce.
    Apr 2004
    326
    Hello,
    Thank you.
    Tell us you don't understand sub-forums... without TELLING us you don't understand subforms..... :-)
    Dec 2022
    1
    Hindustan Industries is one of the most trusted manufacturers of Automatic Sticker labeling machines based in Baddi, Himachal Pradesh, India. We provide world-class Automatic Sticker Labeling Machine solutions based on the latest technology for the packaging and manufacturing industries.
    Visit Our Web: https://hindustanindustries.org/
