586,069 active members*
3,629 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > ST10Y Y axis on face, holes not round
Results 1 to 8 of 8
    Aug 2011
    72
    I am trying to circle mill a small hole with a 1/8" end mill using live tooling and the y axis.
    the hole is centered the the c axis and is 0.31" diameter.
    the problem I am having is that the hole is not round. its is oval. its 0.2905" x 0.273"
    any thoughts?
    CAM is OneCNC
    G28 U0. W0.
    G56
    T1010
    M154
    M133 P3000
    M08
    G98
    M14
    G17
    G00 X0. Z1.75 Y0.
    Z1.55
    G01 Z1.375 F9.
    X0.004 F18.
    G03 Y0.0259 X-0.0219 I-0.0259 J0. R0.0259
    Y0. X-0.0478 I0. J-0.0259 R0.0259
    Y-0.0478 X0. I0.0478 J0. R0.0478
    Y0. X0.0478 I0. J0.0478 R0.0478
    Y0.0696 X-0.0219 I-0.0696 J0. R0.0696
    Y0. X-0.0915 I0. J-0.0696 R0.0696
    Y-0.0915 X0. I0.0915 J0. R0.0915
    Y0.0915 X0. I0. J0.0915 R0.0915
    Y0. X-0.0915 I0. J-0.0915 R0.0915
    Y-0.0269 X-0.0828 I0.0457 J0. R0.0457
    G00 X-0.0828 Z1.625 Y-0.0269
    X0. Y0.
    Z1.425
    G01 Z1.25 F9.
    X0.004 F18.
    X0. Y0.
    Z1.345
    G01 Z1.17 F9.
    X0.004 F18.
    X0. Y-0.0602
    G01 Z1.55 F9.
    Z1.17
    X-0.019 Y-0.0863
    G03 Y-0.0925 X0. I0.019 J0.0261 R0.0323
    Y0.0925 X0. I0. J0.0925 R0.0925
    Y-0.0925 X0. I0. J-0.0925 R0.0925
    Y-0.0863 X0.019 I0. J0.0322 R0.0323
    G01 X0. Y-0.0603
    G00 Z1.625
    Z1.75
    M15
    G18
    M09
    M135
    M155
    G99
    M01
    G28 U0. W0.
    M30
    Aug 2010
    579
    Haas Factory Support
    From the Haas Factory Applications Department:
    There are couples of thing you can do to correct this problem:
    1. There are IJK and R in every G03 line, prefer to use IJK, it is more accurate.
    2. You should be able to use one line of code, e.g. (G03 I-0.0925) to cut a full circle for Y axis machines.
    3. If you want to hold the tolerance better than 0.0005, I would suggest using the C axis tool path, rotate the spindle around the cutter, since this hole is in the center of the lathe spindle.
    4. Check X&Y axis tools center line, the closer the better, and avoid using cutter compensation if possible.
    5. Add a finish cut to avoid a tool deflection.
    Thanks,
    Ken Foulks
    Aug 2011
    72
    Re: Haas Factory Support
    Thank you Ken,
    I would love to use the C axis for this, and other parts. but I have a problem on the software side. i have contacted the publisher and worked with them extensively to resolve the posting issue.. but, long story short, I can ether post so as to use the XY, or post to have the machine convert XY to XC. I cannot do both in one post.
    I can post XC, but If I post with C, the C commands are posted to the 4th decimal and the machine will error. The publisher has said they could not fix that and that I should post for the machine to convert XY to XC. but doing that on center line does strange things. the hole is clean, but the C axis back spins at uncontrolled points.
    Is there a way to have the HAAS control ignore or round the 4th decimal place number?
    Aug 2010
    579
    Please send us an email, include:
    Serial Number
    Contact Information
    Your contact at OneCNC and his/her contact info
    Part Print
    Full Program
    apps (at) haascnc.com
    Thanks,
    Ken Foulks
    Apr 2005
    713
    Quote Originally Posted by KenFoulks View Post
    Ken, can you elaborate on why this was suggested?
    Aug 2011
    72
    I will get the info to you as soon as I can, but I am at a different location today.
    Thank you for your help.
    Aug 2010
    579
    Quote Originally Posted by Matt@RFR View Post
    Cutter comp has tool offsets and other factors that can complicate troubleshooting. Many CAM systems didn't do Y-axis lathe cutter comp very well in the beginning and there were some software issues with earlier versions of Y-axis software.
    Thanks,
    Ken Foulks
    Aug 2011
    72
    Re: ST10Y Y axis on face, holes not round
    Update:
    the problem is entirely software. we did have a tech come and check the machine for another issue, but had him look at this issue as well. he did find and couple small 0.0002 -0.0006 misalignments and dialed it all in. it did not make a difference on the hole shape.
    after a lot of back and forth with the software tech, he finally admitted that there is an issue in the soft ware that prevents it from outputting 3 decimal for the C axis without also limiting all axis to 3 decimals. Also, the software is limited in that you can either do one of three types of face machining, and you need a different post for each one. 1: you can do XY to XC conversion in the controller. 2: you can do true XY movements. 3: you can do XC movement, but only if all axis are reduced to 3 decimals.
    you cannot switch between these in one program, you must change what post is being used for each tool group and either post them separately and edit them together in a text editor, or set them up as sub programs and call them up in the order needed.
    we have been able to produce round holes now with each of the option above, but not at all happy with the limitations of the software. Looking at MasterCam now.
  1. Replies: 5
    Last Post: 04-28-2014, 10:46 PM
  2. Cad/Cam Software for Haas ST10Y with Y axis
    By forged22 in forum Haas Lathes
    Last Post: 11-20-2012, 02:23 PM
  3. holes not coming out round
    By badassdevil in forum DIY CNC Router Table Machines
    Last Post: 04-18-2011, 02:06 AM
  4. How to make an extruded cut on a round face?
    By squale in forum Solidworks
    Last Post: 10-18-2008, 12:41 AM
  5. Round parts with holes on OD
    By CharlesM479 in forum Solidworks
    Last Post: 07-09-2007, 03:08 PM
