587,125 active members*
5,290 visitors online*
IndustryArena Forum > CAM Software > ArtCam Pro > Square peg in a round hole?
Results 1 to 7 of 7
    Apr 2012
    11
    Hi.
    So another basic question regarding cnc.
    So i would like to cut a 90º inside corner (left image) to cut out a square out of the material (10mm thick plastic). Of course since i am using a 1/8 drill i will get something like the center image.
    However i need to fit a square (with sharp edges) inside the hole i am cutting.
    The solution that seems obvious to me would be to do it like the image in the right.
    I could design that into the vector file, but it seems something common enough to have an automated solution, however i cannot find it in artcam.
    The only thing i could find was the inlay option, but that would only work if i could also round out the corners in the piece to be inserted, but since it's cut on it's side that would be very difficult.
    Regards
    Dec 2011
    59
    You don't say which version and build your using, but in general there is no auto feature to do this, fillet only works to the inside so would not work in this case.
    circle, copy paste then weld will be the obvious as this point.
    Gary
    Beckwith Decor Products
    ArtCam Reseller/Trainer, Custom tooling & Onsrud Dealer
    Aug 2008
    199
    the only (as far as i know) software which make this automatically is CAMBAM
    and this feature can save a lot of time!
    for CNC woodcarving - 3d puzzle - furnitures
    http://pagesperso-orange.fr/fabrun/
    Apr 2012
    11
    It's artcam 2010
    tks for the tip fabconv
    it something that seems so common that it's strange to me why it is not to an automatic feature for most softwares
    Jul 2009
    690
    Some Vectric products include that option as well.
    Aug 2008
    199
    aspire include this option but it is not automatic, you have to modify the drawing by clicking each corner!
    Jun 2007
    3734
    Drill square holes
    [ame=http://www.youtube.com/watch?v=ALiqAXiTQBg]Square Hole Drill-bit - YouTube[/ame]
    What's inside.
    [ame=http://www.youtube.com/watch?v=L5AzbDJ7KYI&feature=related]How to Drill a Square Hole - YouTube[/ame]
  1. Making sharp corners in VCarve 3.1
    By Trell in forum Post Processors
    Last Post: 04-23-2011, 04:57 AM
  2. Inside Square Corners
    By Magnum164 in forum Tormach Personal CNC Mill
    Last Post: 08-29-2010, 04:07 PM
  3. Sharp corners
    By renato13 in forum Fanuc
    Last Post: 08-28-2009, 02:51 PM
  4. Replies: 46
    Last Post: 11-25-2008, 02:01 PM
  5. Sharp internal corners
    By Sanghera in forum Uncategorised CAM Discussion
    Last Post: 03-30-2006, 09:46 PM
