587,213 active members*
3,339 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Spot Drilling/Center Drilling Steel 55 HRC
Results 1 to 8 of 8
    Sep 2008
    199
    Hey,
    I'm working with some decently hard steel, it ranges from 53-58 HRC. I need to create a 60 degree countersink on the ends of 7/32" Diam rods. I first tried doing this with a center drill and both ends broke, so I tried a 60 degree spot drill and just broke two of them. Anyone have any advice. What's an RPM I should use? I tried 200 and that didn't work so I went to 1000 and that didn't work either. I'm using my Haas TL-1 Lathe to do this and manually drilling in with my tail stock.
    -JWB
    --We Ain't Building Pianos (TCNJ Baja 2008)
    Feb 2008
    586
    What kind of center/spot drills are you using? Methinks only carbide will hold up against anything that hard. Slow is good here, even with carbide.
    Sep 2008
    199
    I am Using UltraTool Solid Carbide TiAlN Coated Center Drills and M.A. Ford Series 60 Solid Carbide Single Flute 1/4 60 degree Countersinks, I just broke on going at 50 RPM. Any Suggestions?
    -JWB
    Jul 2005
    12177
    I think you are going to keep on breaking center drills or spot drills; the tip grind right at the point is not strong enough to take the forces need to make it cut material that hard.
    What you could try is drilling a small pilot hole with a carbide drill then machine the taper with a very tiny tool; the very tiny tool could be something like a 1/8" two flute end mill.
    I have used this approach on hard stuff but not that hard.
    Sep 2008
    199
    Well my boss man Said I don't have to put the countersink in since I'm having issues but how else can I support these rods when they're extended out 2.2" from my collet and I have to turn them down, I feel I'll get too much bending.
    -JWB
    Sep 2008
    199
    Is it ok If I use a 118 Degree Drill and then put my live center into that even though it's 60 degrees. I know this creates point loads but I can't think of any other way to support both end of these three inch rods when i have to turn down the center inch.
    -JWB
    Sep 2008
    199
    Could I use a Piece of Aluminum with the 60 degree countersink on one side and a 7/32 hole on the other and sandwhich that between my live center and my part?
    -JWB
    Jul 2005
    12177
    Quote Originally Posted by JWB_Machining View Post
    .... i have to turn down the center inch.
    You are not turning down the whole length?
    Make an end cap with a 7/32 hole nice tight fit and the center hole in the opposite end and use this with a live center.
  1. Drilling Steel
    By JWB_Machining in forum MetalWork Discussion
    Last Post: 11-04-2008, 11:34 PM
  2. Spot drilling case hardened steel
    By Zumba in forum MetalWork Discussion
    Last Post: 03-04-2007, 08:32 PM
  3. Spot drilling/chip dragging
    By fpworks in forum MetalWork Discussion
    Last Post: 09-28-2006, 02:59 AM
  4. Drilling a hole in the center of a bolt / newby question
    By stickben in forum Mechanical Calculations/Engineering Design
    Last Post: 04-30-2006, 05:07 PM
  5. Drilling Chrome Steel Help please
    By foamcutter in forum MetalWork Discussion
    Last Post: 04-01-2004, 08:27 AM
