Hi Guys,
Some jobs where I'm using fixtures etc need bolts fitting and removing during machining.
For example, now I'm machining a face that has holes drilled from a previous operation. After facing I need to fit bolts to the holes and tighten it to the fixture.
What I do now is put a "split" in the operation manager and name it such as "remove clamp, fit M8 bolt", just so that it's easy to see what needs to be done and when.
When I generate the G-code, I basically select all, then de-select the split and out pops all the code. I then need to go the point where I want to stop the machine and manually edit in a G28 G91 Z0 and an M00.
What I'd really like is to be able to generate the whole lot, including the "split" and the GPP file reads this and outputs the necessary code.
Example....Generate with SPLIT
Output for my Haas:
G28 G91 Z0
G28 G91 Y0
M00
That's what I want, anyone got any tips?
Maybe I need to read through the help files. Oh for more hours in the day!
Cheers,
Matt.
