587,427 active members*
5,095 visitors online*
Results 1 to 2 of 2
    May 2007
    4
    Spline Programming
    My code only loops at N1 not counting the angle on C axis.
    G28 U0. V0. H0. W0.
    #100 = 20. (Start diameter)
    #101 = 25. (End diameter)
    #102 = 0. (Start C)
    #103 = 10 (Angle between spline teeths)
    #104 = 2. (Start Z)
    #105 = -50. (End Z)
    #106 = 0701 (Tool)
    #107 = 200 (Feed)
    #108 = 0.1 (Cut depth)
    #109 = 359.
    T#106
    M5 M200
    G0 C#102 Z#104 X#100
    M8
    #110 = [ #100 + #108 ]
    N1
    G0 Z#104 X#110 C#102
    N2
    G1 Z#105 F#107
    G0 X#100
    G0 Z#104
    G0 C#111
    #111 = [ #102 + #103 ]
    IF [ #111 LE #109 ] GOTO 2
    IF [ #111 GE #109 ] GOTO 3
    N3
    IF [ #110 LE #101 ] GOTO 1
    G0 Z#104
    G28 U0. V0. H0. W0.
    Jun 2007
    87
    Re: Spline Programming
    The c axis won't increment because you have put a permanent value of 10 degrees to it.
    Change it to this
    (after N1 block)
    N2
    G1 Z#105 F#107
    G0 X#100
    G0 Z#104
    G0 X#110 C#111
    #111 = #111 + #103
    IF [ #111 GE #109 ] GOTO 3 (this line not necessary, last position is always 350°)
    the block N3 is also wrong. it will be an endless loop in cutting X20.1
    it should be #110=#110+#108
  1. Help with Spline
    By jesuscowboy in forum Uncategorised MetalWorking Machines
    Last Post: 06-01-2012, 07:26 PM
  2. Take a look spline job
    By turboless in forum Employment Opportunity
    Last Post: 05-22-2009, 04:04 AM
  3. spline chucking
    By reachraghu in forum Work Fixtures / Hold-Down Solutions
    Last Post: 04-09-2007, 09:14 PM
  4. spline help,mc9.1
    By GRANDPA in forum Mastercam
    Last Post: 03-10-2007, 01:00 PM
  5. Spline
    By scottsss in forum Autodesk
    Last Post: 07-15-2003, 04:30 AM
