587,513 active members*
2,780 visitors online*
IndustryArena Forum > MetalWorking Machines > Shopmaster/Shoptask > Splash lube of spindle bearings
Results 1 to 14 of 14
    Mar 2008
    10
    Question Splash lube of spindle bearings
    According to the manual, the spindle bearings are splash lubricated. As I'm about to replace the spindle bearings, I have a question. Should I pack the spindle bearing in grease if they are splash lubricated?
    It would seem that you would slowly contaminate the oil with the grease in the bearings. If it is splash lubricated, my past experience with such systems is that the bearings are soaked in the same oil as the splash system, and the splash system keeps them lubed.
    But if seems that Shoptask recommends greasing the bearings, and then splash lubricating them which doesn't make much sense to me as the oil won't make it thru the grease, or if it does, will wash it away.
    Any advice from other owners or experts our there as to what way makes the most sense?
    Aug 2007
    22
    I know very little about it. My understanding at this point is that the lathe bearings are splash luricated. The mill bearings are grease lubricated. My advice would be to call shopmaster on there tool free line and ask them if this is the case.
    Mar 2008
    10
    I've tried that. JT says he doesn't know. He says the spindle is splash lubed, but doesn't know why you then need grease.
    That's why I'm posting it here. To me, bearings should either be splash oil, or grease packed lubricated. Both doesn't make sense to me but maybe I'm off base, or the splash lubrication (despite the manual) doesn't reach the spindle bearings and really only lubes and cools the transmission gears. That is the only way to me, it would make any sense.
    Any comments or experiences for other owners?
    Nov 2007
    55
    I have always wondered about the splash lubricated bit myself. It doesn't seem like there is a real positive flow path for the oil. It would be neat to replace the cover plate with plastic for awhile to see how much oil actually gets up there.
    Dennis
    Dec 2005
    183
    Ah ha! Another good one. I know from my bearing swap that the lathe bearings were greased from the factory.
    However, I'm dubious about how much splashing is going on up there. I got a hunk of lexan to use as a cover but ended up removing the tripple gear and hence the ability to splash lube...and then didn't ever put the cover back on. So, I just greased the bearings. I figure if grease works for the mill then it should work for the lathe. I can't see any major harm in having grease and splash though. Based on the ammount of grease still in the bearings it didn't look like any of it has been "washed out" by the oil.
    Nov 2007
    277
    The only time that the lathe spindle bearings can possibly be splashed lubricated is when the power feed is engaged. So you better grease the bearings.
    Aug 2007
    22
    Seems to me that the need for the power feed on to splash lube the spindle bearings was in the manual as well.
    Dec 2005
    183
    Wow you actually read the manual? Is there anything else I should know?
    Nov 2008
    19
    splash spindle bearing lubrication
    Did anyone ever get a real awnser on this issue of grease or no grease for lathe spindle bearings. I also talked to jt some time ago and he could not seem to give me a exact awnser either. When I replaced my spindle bearings on the headstock I think I did grease them, but, as many I wander why I did grease them.
    leeharrysouth
    Mar 2008
    10
    Splash lubrication
    Yes, the manual says to keep the trans in gear at all times to lube the bearings.
    The oil would have a real hard time getting into the bearings considering that its only the gears that sling, not a sling ring which is used in most splash systems. (At least the ones I have seen.). There really isn't a lot of gear in the oil and its at the very bottom. How it can splash much up and sideways was always a mystery.
    I lubed mine, but always wondered how much oil really got to the bearings rather than to the main drive gear. Will probably remain a shoptask design mystery<g>!
    Jul 2005
    151
    After I did the headstock alignment I ran the lathe with the mill head removed, and the oil definitely will splash out the hole in the top of the casting. JT warned me not to overfill the gearbox or it would leak out around the handles, so I think the answer is yes the oil will splash lube the bearings.
    Sep 2008
    14
    Quote Originally Posted by leeharrysouth View Post
    leeharrysouth
    I have been a mechanic for 42 years. Anytime I take something apart that has any kind of bearing I always put on some grease when I reassembly. When the machine initially starts everything is lubricated untill the lube system takes over. It has always worked well for me.
    Nov 2008
    19
    Good Point
    Quote Originally Posted by crsatter View Post
    I to have always done this with mechanical assymblies. Maybe thats the awnser to the question. The grease just covers things until splash takes over.
    leeharrysouth
    Dec 2005
    183
    It sure seems like using grease could help but not using grease could hurt. I also wanted to reiterate that my bearings were greased by the factory and did not appear to have any oil at all in them from splashing.
  1. Spindle lube
    By QSIMDO in forum Charter Oak Automation Support Forum
    Last Post: 10-08-2007, 11:23 AM
  2. Lathe spindle bearings and spindle material
    By mackeym in forum Uncategorised MetalWorking Machines
    Last Post: 08-21-2007, 08:49 PM
  3. Lathe spindle bearings and spindle material
    By mackeym in forum Linear and Rotary Motion
    Last Post: 08-11-2007, 04:53 PM
  4. what kind of lube for linear bearings?
    By Harold Edwards in forum Linear and Rotary Motion
    Last Post: 05-20-2006, 04:32 PM
  5. Spindle lube on 4020
    By Fudd in forum Fadal
    Last Post: 01-22-2006, 06:31 PM
