587,591 active members*
3,852 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Spiral extrude or cut
Results 1 to 6 of 6
    Aug 2005
    177
    This is not what I want but you should get the idea. I need a spiral ramp. I don’t know how to.
    What is the procedure
    Rob
    - - - Updated - - -
    Quote Originally Posted by artracing View Post
    Rob
    I also need it to go 180 degrees not 90
    Apr 2009
    3376
    Re: Spiral extrude or cut
    How big ?
    Helical,meaning both sides parallel as it ramps up ?
    May 2013
    701
    If this is what you need I used to spiral a inner and a outer and connected them with a line and then skinned then extruded the surface for thickness and then added to a cylinder. (Have the output set arcs when doing the spirals)
    Kind of a Paine but it seems to work there may be easier ways
    RAF.
    Aug 2005
    177
    Quote Originally Posted by jrmach View Post
    How big ?
    Yes. Exactly. Using it as a rotary clamp
    1.5” OD
    Rob
    Aug 2005
    177
    How big ?
    Your question trigger a thought.
    I used spiral line with 1.5” od and .5” id and joined the ends with line and then skinned.
    Looks correct
    Aug 2005
    177
  1. Extrude a cut?
    By phil m in forum Rhino 3D
    Last Post: 12-23-2013, 11:25 AM
  2. Extrude Gear
    By bohunter11 in forum BobCad-Cam
    Last Post: 03-21-2013, 03:32 AM
  3. Extrude cut
    By mrsammy in forum Solidworks
    Last Post: 11-17-2011, 11:50 AM
  4. Can't extrude.
    By 7yler in forum BobCad-Cam
    Last Post: 10-03-2010, 12:16 AM
  5. how to extrude
    By gits in forum Solidworks
    Last Post: 09-11-2010, 06:53 PM
