Re: Spindle winding up whenever parallel connection is made?
For one, you should have a hard wired E-stop circuit in place where the machine has to be Taken out of e-stop via a start P.B. to energize the spindle and servo's main power and any other motors, also the charge pump should be part of this string.
What form/type of spindle is it and how is the spindle started?
Al.
Albert E.
