Hi All,
Is anyone with a homebuilt machine using anything bigger than a laminate trimmer or die grinder? I was thinking of upgrading to a porter cable router but they only seem to be available in 120VAC and the cost of a 1500W 240to120VAC transformer will pretty much double the total cost of the router.
So what else can i use? haven't got the money to fork out for HF spindle and inverter. Is there anything as easy to mount as the porter cable available here in Aus?
Cheers
Matt
