I have two 750w B&D routers which I don't use now as I have an Ryobi 1500w.
Anyway these B&D routers are similair in body shape to those Kress router/drill.
When under load these tend to be a bit noisy and was pondering whether it be the plastic casing they're housed in? so it got me thinking about sandcasting a round body in aluminium and house it in this,plus better bearings to suit the armature shaft.
Anyone think that an aluminium body would dampen the noise a bit bearing in mind the thickness of the wall of the housing will be about 3mm or 4mm
