Sounds like the spindle preload is too tight, slack the nut that's between the pulley and the headstock about 1/16th of a turn (in other words, just a smidgen) and run it for a bit and see if it improves.
Originally Posted by
xaruum
Any one have any experience on what the spindle temps should normally run for the taig mill?
Even at the lowest pulley setting ~1100rpm my spindle is getting over 160f ( darn $10 thermometer read any high higher ) in just 5-6 minutes! The bridgeports I used to work on would get warm to the touch, but not burning hot!
Thoughts?
Nick Carter
Largest resource on the web about Taig lathes and mills
www.cartertools.com
