587,349 active members*
3,601 visitors online*
Results 1 to 2 of 2
    May 2005
    1
    spindle speed control
    can anyone point me in the right direction, what I want is to be able to control my spindle speed from using mach2 or 3, do i use a ac or dc motor. Then what do i need, is it a variable speed control board like the one on cnc4pc web site (i`ve got his breakout board) then do you need a vfd drive, or is that for ac motors only what do you need for a dc motor. i will be thankful for any help
    35538
    THe CNC4PC board will control a VFD, which is used with 3 phase AC motors. If you're spindle is DC, with a manual speed control, then the Digispeed from www.homanndesigns might be able to control it.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
