587,228 active members*
4,099 visitors online*
Results 1 to 6 of 6
    Apr 2017
    8
    spindle recommendation please
    I have a Merchant Dice machine which runs well and is ideal for me to learn on. Problem is the Kress router which came with the machine has burnt out/stopped working after only a few hours of operation. I've read that this is a common problem with these routers so need to upgrade. I don't have much technical nohow but am thinking a watercooled chinese spindle capable of cutiing both wood (primarily) and soft metals where needed.
    Any advice is very much appreciated as to where/who to buy from.
    I have had a look on both ebay and Amazon but not really sure what would be best to use with my machine.
    I realise I will require a new spindle mount, pump etc so any help with links to these as well would be most helpful.
    I should mention, I am using the machine to cut out guitar bodies primarily.
    Thanks in advance
    Neil
    Mar 2017
    164
    Re: spindle recommendation please
    Im a total noob and just learning and don't want to send you in the wrong direction, but there's a member who is also making guitars etc , and he's using this one and quite happy with it .
    I'm buying one myself and will be interested to hear what the experts here have to say
    TOP QUALITY 3KW WATER-COOLED MOTOR SPINDLE ENGRAVING MILL GRIND 220V | eBay
    Apr 2017
    8
    Quote Originally Posted by MajorTendonitis View Post
    Hey, thanks so much for taking the time to reply, I really appreciate any help, I'm a complete novice at cnc myself so pointing me in any direction is better than me going in circles
    Mar 2017
    164
    Quote Originally Posted by lawdayinst View Post
    As I mentioned I'm just learning , and I certainly don't want to steer you wrong . I'm hoping the resident experts give us some input . I know Davids very pleased with his , and it's unbelievable quiet.
    Your are aware that you need a VFD to run a spindle right ? They don't just plug in like a router .
    i posted the link for the one he uses . I was told not to cheap out on the VFD , as they can produce unwanted noise into the systems electronics
    https://www.driveswarehouse.com/wj200-022sf-2527
    Apr 2017
    8
    Thanks again,
    I knew I needed a VFD but have no real idea what they do! I'm assuming having looked at a couple that they are some kind of transformer, turning 2 phase into 3 phase? I notice many are sold as part of a package on Amazon.
    May 2012
    231
    If you have not bought anything as of now. Ebay have a lot of them with vfd and spindle together you will want something in 2.2 or larger Just make sure that you can get a spindle clamp that will fit our spindle if you go with a water cooled one. You can use a garden type water pump ( like little giant pump for a corner water fall 3/8 inch hoses).
  1. Replies: 6
    Last Post: 07-10-2015, 10:38 PM
  2. Spindle and VFD recommendation
    By texasinmi in forum Uncategorised WoodWorking Machines
    Last Post: 05-08-2015, 02:37 AM
  3. Chinese Spindle Recommendation
    By Rob K in forum DIY CNC Router Table Machines
    Last Post: 12-28-2012, 06:17 PM
  4. Looking for spindle recommendation for carving foams
    By creaturemaker in forum Maintenance DIY Discussion
    Last Post: 03-28-2012, 09:15 PM
  5. spindle and VFD recommendation
    By telah in forum DIY CNC Router Table Machines
    Last Post: 07-04-2011, 02:55 PM
