Originally Posted by
SCzEngrgGroup
All you should have to do is set the "Top Height" in Fusion high enough above the top of the hole that you can be certain the tap is fully backed out of the hole before reaching that height. Something like 1/2" above the top of the hole will usually be enough.
I will give you a warning about the Procunier tapping heads: Unlike most other tapping heads, the Procunier cannot tolerate ANY over-feed on the way down. This means you MUST KNOW your actual spindle RPM when tapping, or intentionally under-feed to ensure you NEVER exceed 100% feed. If you do over-feed, you WILL break the tap, if not the Procunier itself.
Regards,
Ray L.
