586,031 active members*
2,753 visitors online*
Results 1 to 4 of 4
    Aug 2013
    18
    Spindle for DIY mill build
    Hi- I recently acquired a older (never used) Sauter driven tool originally designed for use in a tool turret. Model #0.5.934.104-103 803 / 31223D. It uses HSK C40 tooling (manual tool changes only).
    Schematic and pics below.
    I have been searching for a suitable spindle for a small bench (5Bears style) mill I have built (currently crippled with a router as spindle).
    I was thinking of changing out Drive Gear for timing pulley and driving it with a 750 W yaskawa servo motor I have.
    Has anyone tried to use a driven tool as a stand alone spindle ??
    Thx for ideas.
    Jake
    Attachment 254082
    Sent from my iPad using Tapatalk
    Aug 2013
    18
    Re: Spindle for DIY mill build
    HI- here are few more pics and the schematic from the company- I assume those are 2 AC bearings in nose...
    Thx for any comments re. suitability as a spindle on a small DIY bench mill.
    thx
    jake
    Attachment 254128Attachment 254130Attachment 254132Attachment 254134Attachment 254136
    Jun 2013
    1041
    I haven't used one but it looks like it should be no problem. I'm sure it will be a vast improvement over any mini mill spindle.
    Ben
    Mar 2013
    39
    Looks like it'll be a vast improvement over any bench top mill spindle, 10,000 rpm and 13hp yes please.
    Does it have ports for air hoses? Labyrinth Seal?
    Did you manage to get any more tooling with it? HSK C40 may be rather pricy.
    Cheers, Fenza
  1. Mini Mill X2 Spindle Head + VFD + Chinese Spindle= custom!
    By diyengineer in forum Uncategorised MetalWorking Machines
    Last Post: 12-26-2016, 10:04 PM
  2. Small mill build X2 spindle
    By dick cnc in forum Vertical Mill, Lathe Project Log
    Last Post: 10-23-2013, 12:42 AM
  3. Sub spindle build
    By jake hoback in forum Tormach Personal CNC Mill
    Last Post: 08-09-2013, 05:26 PM
  4. Sweo spindle drive? new mill dead spindle
    By Shizzlemah in forum Fadal
    Last Post: 12-18-2008, 06:11 PM
  5. Build you own Spindle
    By BeerFizz in forum DIY CNC Router Table Machines
    Last Post: 12-07-2006, 02:21 PM
