587,719 active members*
3,468 visitors online*
    May 2009
    1346
    Spindle Cooling Water Connections
    Never used a water cooling spindle and now that I got a 800W ER11 water cooling spindle I don’t understand how the plastic hoses will connect to the spindle.
    Attached are 2 images of my connectors. Do you just slip the hose into the connector and tight the nut to make a water tight connection or you need some kind of other type fittings?
    Nicolas
    Nov 2012
    1272
    Re: Spindle Cooling Water Connections
    You got it. Unscrew the nut, push the hose onto the barbed nipple all the way, tighten the nut.
    May 2009
    1346
    You made my day CitizenOfDream, thanks
    Nicolas
  1. WATER COOLING SPINDLE 0-24000 rpm ??? is this possible?
    By luis81 in forum Uncategorised MetalWorking Machines
    Last Post: 02-26-2021, 05:38 PM
  2. Water cooling a 2.2kW spindle with cpu radiator ?
    By fuzzyz1 in forum DIY CNC Router Table Machines
    Last Post: 04-25-2016, 03:26 AM
  3. Water cooling or air cooled spindle
    By limacchina in forum Uncategorised WoodWorking Machines
    Last Post: 12-25-2012, 01:48 AM
  4. Spindle water cooling system
    By jafc76 in forum Videos
    Last Post: 09-03-2012, 03:30 PM
  5. Spindle water cooling 101. The right way.
    By diyengineer in forum Uncategorised MetalWorking Machines
    Last Post: 06-28-2010, 05:20 AM
