Originally Posted by
the_gentlegiant
Greetings,
Let's start here... do not change the contact angle on your bearings. Contact angles are very specific to the need at hand. Just replace with what exactly is in there. Even though I know a couple things about super precision bearings, neither of us knows enough about spindle design and engineering to change something as drastic as that. You don't mention what the spindle is out of or its top speed, but if you must get fancy, consider some manufactures "robust" series or ceramics. I think many basic designs can be had with a higher ball compliment, which may be stiffer, but may have other trade offs like noise and heat generation. Consult the manufacturer's literature concerning their alternate systems.
