587,485 active members*
3,231 visitors online*
Results 1 to 2 of 2
    Oct 2009
    75
    Question Spherical Void - Too Shallow
    I tried cutting a hemispherical void of 0.502" in diameter in a piece of MDF. I used a 1/4" ball mill for the milling. The void looked fine, but when I placed a ball with a diameter of 0.500" in the void it sat noticeably above the equatorial plane of the ball (like the pocket was either too shallow or the sphere-shaped void's diameter was too small. Any thoughts of what went wrong?
    Greg
    Feb 2010
    62
    Re: Spherical Void - Too Shallow
    Hi Greg,
    Indeed the ball in your example will not exactly fit the hole that you machined, for a few reasons:
    - the STL approximates the real sphere using flat triangles, making the hole a bit smaller
    - DeskProto machines using toolpaths at a certain path distance (the Precision values). DeskProto will not remove too much material, so the tolerance value will always result in some extra material left. See the Help file on "Distance between toolpaths".
    - The calculation algorithm works with Z-grids (see the Help file), and as a result the void that is spherical in the STL will not be exactly spherical in the resulting part. For this reason DeskProto is not suited for toleranced mechanisms like a piston in a cylinder.
    Lex.
  1. Shallow hole tapping
    By Tippy1 in forum MetalWork Discussion
    Last Post: 03-13-2013, 03:01 PM
  2. small steps on a shallow taper
    By Roll1 in forum Fanuc
    Last Post: 08-18-2011, 10:49 PM
  3. Surface shallow
    By gorby in forum Mastercam
    Last Post: 12-10-2009, 04:10 AM
  4. Steep Shallow toolpath
    By camtd in forum Surfcam
    Last Post: 03-14-2007, 11:28 PM
  5. Shallow depth of cut.. ???
    By Eddieweeks in forum Fadal
    Last Post: 11-17-2005, 08:55 PM
