587,913 active members*
3,765 visitors online*
    Jul 2009
    115
    Source for stainless steel powder
    I have been reading some posts concerning people who used bolts and epoxy to build tables for their CNC builds and they were adding stainless steel powder to the epoxy. I was wondering if anyone knew of a source for the stainless steel powder. I found one source on e-bay that was $10/lb plus $7 shipping which based on the posts I was reading sounded a bit expensive, but the prices I saw on e-bay were in the same ball park.
    Aug 2011
    999
    Re: Source for stainless steel powder
    If the intent is only to fill the epoxy for better modulus or less thermal expansion I can not see a reason to specifically use stainless steel powder. Since the epoxy is in any case several magnitudes softer than the filler powder you could use just as well aluminum powder or even washed quartz sand. That said, if you want to drill or tap the hardened epoxy, the sand would not be good for your tools but the aluminum better than the steel.
    Box Joint and Dovetail CAM software here: WWW.TAILMAKER.NET
    Mar 2014
    735
    Devcon makes an epoxy with stainless, aluminum and even titanium fillers. I can get the product number for you if you cant find it. I have a can of their plastic steel liquid and it was listed in the direction sheet that came with it.
  1. Source for 3" x 0.5" Wall, Stainless Steel Tubing
    By syscore in forum Tormach Personal CNC Mill
    Last Post: 04-19-2017, 12:00 PM
  2. Stainless or non stainless steel ACME screws?
    By amanmazleigh in forum Linear and Rotary Motion
    Last Post: 07-07-2011, 05:00 AM
  3. stainless steel
    By cboys22 in forum MetalWork Discussion
    Last Post: 11-03-2010, 03:50 AM
  4. Stainless Steel
    By jdclark in forum Shopmaster/Shoptask
    Last Post: 02-25-2009, 05:08 AM
  5. Stainless Steel ?
    By Depoman in forum MetalWork Discussion
    Last Post: 01-12-2005, 12:40 PM
