I was wondering what advantage in stiffness a 2" x 4" x 1/4" rectangular tubing was over a 4 inch C channel on a 4' cutting Width "Y"(56"-58") would be?
I just got done with my Solsylva 24" x 48" and was pleased as all get out with it for what I wanted to do
so this might be a long post.
I vacuform some things and it cuts the outside shape out LOTS better than I ever could(really I'm worse than you can imagine!). Any way the Wife got involved in a discussion with me ( asked what it could do. I told her LOTS, but SLow due to the Allthread that I used and even the later 1/2" -10 acme). She saw a youtube video of cabinet making and decided for me to build her a cabinet over 3 foot wide 72 inched tall! She has wanted for a while. $%% ??? it won't fit my machine . so I tell herI'll have to upgrade to a bigger machiine. yup cost came up then. I saw a user on here that had built a V bearing machine from solsylva and thought it would scale nice in the X direction but might give me a fit in the Y, I contacted the Author of the plans and he said scaling up x "no problem" Y requires a bit more. I like his design a lot. If will go on a welded steel frame table made from 2" x3" x /14" tubing and laser squared by a friend at a machine shop so that's taken care of but the "Y" problem still bugs me. so does rectangular thick wall tubing (capped with 1/2 plate and TIG welded solid on the ends so I can thread it to the gantry plates) seem like a viable option? the particulars of the electronic's are a 4 axis Gecko g540 48v, 380oz steppers kit from CNCrouterparts. the x will be rack and pinion with a mid mounted stepper and 2 outboard pulleys running the pinions shown in the picture that I hope shows up. right now it's drawn up as a 6" c channel and the author has some reservations on it due to my low 380 oz stepper motors. I like the simplicity of the design and also the fact that I can do 99% of it except for the leveling/squareness of the steel table and tig"ing the end caps.
any input would be appreciated on the differences in c channel vs square tubing. and suggestions on a work around
thanks
Ps I'd love to have been able to get a "kit " for this but it's just not in the budget for me and I LIKE working on stuff to make thing work. I built a proto form Vacuum former and kicked it out to a 2' x 6' size so I could make my obsolete car parts since no one make many parts for old dodge dart convertibles. (plus I want to make creature comfort parts for the convertible like built in cup holders,power centers on the custom console,door panels to replace my old ones since I have power windows instead of cranks, and speakers so that you can really hear music from more than the dash speaker)
