Included is a Modified FANUC2013 Turn postprocessor for SolidCam, posted by some kind person on this forum. I don't remember exactly where i downloaded it.
I sat down to make it work with my Mach3 lathe and Solidcam2015, studied the Gcode, and found what needed to bed fixed.
I have done the following modifications to make it work with Mach3:
Removed the program number with colons which made mach3 protest.
Included missing spindle speed in a G98/G97 line, which made mach3 protest.
Adjusted the startup and end coordinates to fit within my relatively small (14") lathes working area. ADJUST THESE TO FIT YOUR MACHINE!!!
Swapped G2 and G3 because solidcam works above the part, and mach3 below the part. X and Z directions are the same, but arcs go the wrong way.
Swapped arc direction by changing where the radius is output as negative vs positive, for the same reason as above. Puts the arc on the right side of the desired path.
The post was tested by drawing up a test part, with inside and outside turning, arcs and angles in several directions with 2 tools in one operation.
It ran fine without any problem, just loaded and pressed cycle start.
Picture of part and simulation screenshot in mach3 included in the zip, posttest1/2/3.jpg
I take no responsibility for any faults in the modified post. It works for me, and i hope it works for you as well.
Have fun!
