I'm having problem with solidcam outputting the correct gcodes.
I built a simple part with solidwork and used solidcam12 to generate the gcodes and simulated it and everything look fine but when I load the gcode to mach3 the toolpath look nothing as I expected. The two holes are way off scale... I can't seem to find out where I could of made the mistake. It seem like when when ever I create the circle it alway off scale, alot bigger than I expected. I'm using the FANUC post processor as the default CNC controller.
Thanks in advance
Here is the pic of the actual part from soldicam.
And here is the tool path when loaded in mach3.
Here is the actaul gcode from solidcam.
DUSTCOVER.TAP.txt
