Hi, first post here, need help for SolidCam part pattern, if it's possible of course...
So the thing is I have plastic sheet (1200x600mm), from that sheet I need to get 50 smaller pieces (50 exact the same toolpaths),
At first I thought that I would use Mach3 offsets and use sub program of same toolpath, but I cannot get it working - its so simple but so complicated at the same time. First - Mach3 decides to clear second (G55) offset value and much more problems.
So what would be the best solution for this specific job? I thought maybe SolidCam has "pattern" or pre processor Offsets?
Any ideas? Thanks.
