587,490 active members*
6,005 visitors online*
    May 2017
    2
    SolidCAM to Mac3 pocketing
    I apologise if I have posted this in the wrong place, I am new to this forum.
    I am running Mach3 on a Chinese CNC3020 machine.
    Models are produced in Solid works and programmed in SolidCAM, the post processor I am using is gmill_Tormach_3x_Eval
    My problem is that the Z axis will not move down when running a pocketing or HSM program, it operates perfectly when profiling and during manual operation, but just sits at the same level working through the 'X' 'Y' movements when pocketing.
    Have I missed a setting somewhere or am I using the wrong post.
    Incidentally, I do not get the same problem when posting from ArtCAM,, the machine will cut a 3D relief with no problem.
    Any help or suggestions would be greatly appreciated.
    Dave
    Oct 2013
    153
    Re: SolidCAM to Mac3 pocketing
    Hi Dave
    Are you new to solidcam ? . Did you simulate the program in solidverify ? Does the simulation ran as you intended ?
    May 2017
    2
    I would not call myself an expert as I do not get lots of time to practice, I am a manufacturing engineer and tend to problem solve rather than full blown production.
    To answer your question ....... yes I have run the solid verify simulation and everything ran perfectly, this is why I thought it may be the post i.e. a problem 'after' the simulation, this was also why I loaded it and ran it in Mach3 with confidence, only to discover the 'Z' axis problem.
    Just to add some background, I bought the little CNC3020 to get up to speed with the programming, I am not particularly worries about the accuracy of the machine just how it functions, I am also building a larger 4 axis machine from scratch, so this is all good input.
    Many thanks for your prompt reply.
  1. Pocketing VS 2.5D pocketing under ruffing in SC8
    By scottsss in forum SprutCAM
    Last Post: 10-01-2013, 10:02 PM
  2. Pocketing in V9 help
    By Joe Rodney in forum Mastercam
    Last Post: 02-26-2007, 06:57 PM
  3. Pocketing
    By dneisler in forum BobCad-Cam
    Last Post: 12-19-2005, 05:57 AM
  4. Pocketing
    By Mortek in forum OneCNC
    Last Post: 04-08-2003, 10:08 PM
