Hi, can any body tell me how i get Solidcam to write programs in Heidenhain .H format instead of g code? Do I need a different postprocessor? & where would i get one from?
I use Solidcam all the time.. 2.5D... I have edited my post a lot to get it like
I want.. (Fadal VMC15).. but never heard of .H format...
how to edit post SolidCAM Who can tell me???
CAD/CAM
go to
C:\Program Files\SolidCAM2006R10\Gpptool
and edit Fadal2_M4.GPP or whatever file for your machine..
Eddie
btw... if anyone wants it I have a well tested post for Solidcam + Fadal VMC
Thank you
CAD/CAM
do u have for mach3? pp
no.. sorry only Fadal VMC
So it's possible for the user to modify the Solidcam posts? How many posts do they give you with the system? Do you have to buy any other program to edit a post?
Mike Mattera
Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
http://www.tipsforcadcam.com
No you dont need to buy any program to edit post. Gpptool is it in SolidCam. There is even a manual how to doit.
Do anyone have fadal post for solidcam?
So nobody have fadal post for solidCAM.... Ok so i will write Santa to
Where or how do I get the manual detailing how to edit the Solidcam Post Processor files?
I know how to get into the relevant post file in order to make modifications but don't know how to make changes as everything seems to be text based commands, which I can't make sense of
Get in touch with your reseller. I know for a fact that there are many posts written for H'hain conversational in SolidCAM (I have one for a Hermle C20U with iTNC 530).
It is easy to write your own (I have) and the manual is listed under the help pages or may be downloaded from the SolidCAM website in PDF format. You only need Notepad to write a post, but a backplotter is very useful - I use CIMCO Edit V5.
The hard thing to do is deciding how to handle tool changes and initialisation codes, things like turning the spindle on, pre-positioning for drilling cycles etc. It is a good idea to write a spec for your own reference together with some sample code.
thanks your interest,
i have deckel maho 104 v with itnc 530 and this is a sample nc codes for this machine:
#######CORNER ALONG TOOLPATH###########
10 BEGIN PGM 2krs MM
11 ; Date : 03.12.07 - 21:34:23
12 BLK FORM 0.1 Z X-170.067 Y-95.067 Z-50.
13 BLK FORM 0.2 X0.0 Y95.067 Z-20.
14 ; TOOL TYPE : BALLNOSED
15 ; TOOL ID : 2 krs
16 ; TOOL DIA. 2. LENGTH 10.
17 TOOL CALL 1 Z S1500 DL+0.0 DR+0.0
Q1= 400 ; PLUNGE FEEDRATE
Q2= 500 ; CUTTING FEEDRATE
Q3= 3000 ; SKIM FEEDRATE
18 CYCL DEF 32.0 TOLERANCE
19 CYCL DEF 32.1 T0.03
20 CYCL DEF 32.2 HSC-MODE:0
21 ;
22 ; TOOLPATH : 2krs
23 L X-85.034 Y0.0 FQ3 M03
24 L Z15.381 M8
25 L X-132.235 Y-47.986
26 L Z-44.619
27 L Z-49.619 FQ1 M90
28 L X-132.238 Y-47.190 FQ2
29 L Y47.135
30 L X-132.236 Y47.931
31 L X-132.221 Y48.329
32 L X-132.190 Y48.725
33 L X-132.142 Y49.120
34 L X-132.077 Y49.513
35 L X-131.997 Y49.903
36 L X-131.788 Y50.671
37 L X-131.658 Y51.047
38 L X-131.514 Y51.418
39 L X-131.177 Y52.138
40 L X-130.983 Y52.486
41 L X-130.780 Y52.828
42 L X-130.559 Y53.159
43 L X-130.327 Y53.483
44 L X-130.080 Y53.794
45 L X-129.820 Y54.096
46 L X-129.548 Y54.386
47 L X-129.267 Y54.668
48 L X-128.969 Y54.931
49 L X-128.663 Y55.185
50 L X-128.348 Y55.429
51 L X-128.021 Y55.655
52 L X-127.684 Y55.868
53 L X-127.340 Y56.067
54 L X-126.989 Y56.254
55 L X-126.628 Y56.423
56 L X-126.261 Y56.575
57 L X-125.888 Y56.713
58 L X-125.509 Y56.836
59 L X-125.126 Y56.942
60 L X-124.738 Y57.034
61 L X-124.347 Y57.108
62 L X-123.954 Y57.165
63 L X-123.558 Y57.205
64 L X-123.160 Y57.228
65 L X-122.365 Y57.238
66 L X-37.592
67 L X-36.796 Y57.226
68 L X-36.399 Y57.202
69 L X-36.003 Y57.160
70 L X-35.609 Y57.101
71 L X-35.219 Y57.025
72 L X-34.832 Y56.931
73 L X-34.449 Y56.823
74 L X-34.071 Y56.699
75 L X-33.699 Y56.559
76 L X-33.332 Y56.405
77 L X-32.973 Y56.233
78 L X-32.621 Y56.046
79 L X-32.278 Y55.846
80 L X-31.942 Y55.633
81 L X-31.617 Y55.403
82 L X-31.303 Y55.159
83 L X-30.997 Y54.905
84 L X-30.703 Y54.636
85 L X-30.148 Y54.066
86 L X-29.647 Y53.448
87 L X-29.197 Y52.791
88 L X-28.992 Y52.451
89 L X-28.802 Y52.100
90 L X-28.631 Y51.741
91 L X-28.472 Y51.377
92 L X-28.328 Y51.006
93 L X-28.199 Y50.629
94 L X-28.089 Y50.247
95 L X-27.994 Y49.860
96 L X-27.913 Y49.471
97 L X-27.854 Y49.077
98 L X-27.806 Y48.682
99 L X-27.777 Y48.285
100 L X-27.764 Y47.888
101 L X-27.762 Y47.490
102 L Y-47.233
103 L X-27.767 Y-48.029
104 L X-27.784 Y-48.427
105 L X-27.820 Y-48.823
106 L X-27.872 Y-49.217
107 L X-27.941 Y-49.609
108 L X-28.027 Y-49.998
109 L X-28.128 Y-50.383
110 L X-28.243 Y-50.763
111 L X-28.376 Y-51.139
112 L X-28.525 Y-51.508
113 L X-28.690 Y-51.870
114 L X-28.870 Y-52.225
115 L X-29.063 Y-52.572
116 L X-29.270 Y-52.912
117 L X-29.730 Y-53.562
118 L X-30.244 Y-54.169
119 L X-30.520 Y-54.457
120 L X-30.803 Y-54.735
121 L X-31.103 Y-54.998
122 L X-31.413 Y-55.247
123 L X-31.732 Y-55.484
124 L X-32.060 Y-55.709
125 L X-32.397 Y-55.921
126 L X-32.745 Y-56.115
127 L X-33.100 Y-56.294
128 L X-33.462 Y-56.461
129 L X-33.831 Y-56.609
130 L X-34.204 Y-56.747
131 L X-34.584 Y-56.864
132 L X-34.969 Y-56.967
133 L X-35.357 Y-57.052
134 L X-35.749 Y-57.122
135 L X-36.143 Y-57.175
136 L X-36.540 Y-57.213
137 L X-36.937 Y-57.232
138 L X-37.733 Y-57.238
139 L X-122.506
140 L X-122.904 Y-57.236
141 L X-123.301 Y-57.222
142 L X-123.698 Y-57.192
143 L X-124.093 Y-57.145
144 L X-124.486 Y-57.082
145 L X-124.876 Y-57.002
146 L X-125.262 Y-56.907
147 L X-125.645 Y-56.796
148 L X-126.021 Y-56.667
149 L X-126.392 Y-56.522
150 L X-126.756 Y-56.363
151 L X-127.114 Y-56.189
152 L X-127.465 Y-56.001
153 L X-127.805 Y-55.795
154 L X-128.137 Y-55.575
155 L X-128.461 Y-55.344
156 L X-128.773 Y-55.097
157 L X-129.076 Y-54.839
158 L X-129.366 Y-54.567
159 L X-129.649 Y-54.287
160 L X-129.913 Y-53.989
161 L X-130.168 Y-53.684
162 L X-130.413 Y-53.370
163 L X-130.642 Y-53.045
164 L X-131.054 Y-52.364
165 L X-131.242 Y-52.013
166 L X-131.411 Y-51.653
167 L X-131.565 Y-51.286
168 L X-131.704 Y-50.913
169 L X-131.828 Y-50.535
170 L X-131.935 Y-50.152
171 L X-132.029 Y-49.765
172 L X-132.104 Y-49.374
173 L X-132.161 Y-48.981
174 L X-132.202 Y-48.585
175 L X-132.235 Y-47.986
176 L X-128.626 Y-47.932 Z-47.346
177 L X-128.627 Y-47.475 Z-47.342
178 L X-128.617 Y-43.841 Z-47.320
179 L X-128.616 Y-31.270 Z-47.317
180 L Y34.795
181 L X-128.619 Y44.528 Z-47.324
182 L X-128.629 Y47.737 Z-47.346
183 L X-128.622 Y48.061 Z-47.345
184 L X-128.599 Y48.374 Z-47.346
185 L X-128.565 Y48.657 Z-47.348
186 L X-128.511 Y48.962 Z-47.351
187 L X-128.445 Y49.250 Z-47.352
188 L X-128.372 Y49.520 Z-47.359
189 L X-128.292 Y49.766 Z-47.361
190 L X-128.190 Y50.032 Z-47.365
191 L X-127.982 Y50.487 Z-47.372
192 L X-127.847 Y50.734
193 L X-127.720 Y50.944 Z-47.378
194 L X-127.441 Y51.346 Z-47.379
195 L X-127.151 Y51.696 Z-47.381
196 L X-126.967 Y51.893 Z-47.380
197 L X-126.798 Y52.058 Z-47.384
198 L X-126.639 Y52.201 Z-47.379
199 L X-126.427 Y52.376
200 L X-126.058 Y52.646 Z-47.375
201 L X-125.832 Y52.788 Z-47.373
202 L X-125.406 Y53.022 Z-47.368
203 L X-125.147 Y53.142 Z-47.365
204 L X-124.671 Y53.322 Z-47.356
205 L X-124.386 Y53.410 Z-47.353
206 L X-124.108 Y53.481 Z-47.350
207 L X-123.839 Y53.534 Z-47.347
208 L X-123.538 Y53.580 Z-47.346
209 L X-123.224 Y53.612 Z-47.345
210 L X-122.911 Y53.626 Z-47.347
211 L X-118.623 Y53.617 Z-47.320
212 L X-104.455 Y53.616 Z-47.317
213 L X-50.330
214 L X-40.218 Y53.619 Z-47.324
215 L X-37.048 Y53.625 Z-47.345
216 L X-36.745 Y53.609
217 L X-36.434 Y53.576
218 L X-36.126 Y53.526 Z-47.346
219 L X-35.856 Y53.472 Z-47.349
220 L X-35.590 Y53.403 Z-47.353
221 L X-35.307 Y53.314 Z-47.356
222 L X-34.834 Y53.132 Z-47.364
223 L X-34.576 Y53.012 Z-47.366
224 L X-34.156 Y52.780 Z-47.372
225 L X-33.927 Y52.635 Z-47.374
226 L X-33.555 Y52.361 Z-47.377
227 L X-33.349 Y52.191 Z-47.378
228 L X-33.022 Y51.879
229 L X-32.837 Y51.682 Z-47.379
230 L X-32.550 Y51.331 Z-47.376
231 L X-32.390 Y51.108 Z-47.373
232 L X-32.141 Y50.711 Z-47.371
233 L X-32.009 Y50.467 Z-47.368
234 L X-31.797 Y49.997 Z-47.363
235 L X-31.702 Y49.744 Z-47.357
236 L X-31.618 Y49.482 Z-47.354
237 L X-31.547 Y49.215 Z-47.350
238 L X-31.485 Y48.931 Z-47.347
239 L X-31.431 Y48.624
240 L X-31.398 Y48.332 Z-47.343
241 L X-31.378 Y48.027
242 L X-31.372 Y47.371 Z-47.344
243 L X-31.382 Y43.739 Z-47.320
244 L X-31.384 Y28.784 Z-47.317
245 L Y-34.495
246 L X-31.381 Y-44.618 Z-47.324
247 L X-31.371 Y-47.806 Z-47.346
248 L X-31.382 Y-48.133 Z-47.344
249 L X-31.408 Y-48.446 Z-47.345
250 L X-31.448 Y-48.737 Z-47.347
251 L X-31.501 Y-49.022 Z-47.350
252 L X-31.573 Y-49.319 Z-47.353
253 L X-31.648 Y-49.583 Z-47.358
254 L X-31.729 Y-49.825 Z-47.362
255 L X-31.834 Y-50.092 Z-47.365
256 L X-32.055 Y-50.558 Z-47.375
257 L X-32.178 Y-50.780 Z-47.376
258 L X-32.311 Y-50.994 Z-47.380
259 L X-32.592 Y-51.393 Z-47.383
260 L X-32.904 Y-51.760 Z-47.388
261 L X-33.066 Y-51.930 Z-47.384
262 L X-33.246 Y-52.102 Z-47.388
263 L X-33.608 Y-52.408 Z-47.383
264 L X-34.004 Y-52.690
265 L X-34.208 Y-52.816 Z-47.378
266 L X-34.441 Y-52.945 Z-47.376
267 L X-34.892 Y-53.161 Z-47.367
268 L X-35.148 Y-53.260 Z-47.363
269 L X-35.403 Y-53.350 Z-47.362
270 L X-35.659 Y-53.423 Z-47.355
271 L X-35.951 Y-53.494 Z-47.353
272 L X-36.232 Y-53.548 Z-47.348
273 L X-36.519 Y-53.587 Z-47.345
274 L X-36.839 Y-53.617 Z-47.346
275 L X-37.156 Y-53.628 Z-47.347
276 L X-41.471 Y-53.618 Z-47.320
277 L X-57.235 Y-53.616 Z-47.317
278 L X-110.165
279 L X-119.503 Y-53.619 Z-47.324
280 L X-122.718 Y-53.629 Z-47.346
281 L X-123.038 Y-53.622 Z-47.345
282 L X-123.352 Y-53.601 Z-47.347
283 L X-123.639 Y-53.567 Z-47.348
284 L X-123.946 Y-53.514 Z-47.350
285 L X-124.230 Y-53.451 Z-47.353
286 L X-124.502 Y-53.379 Z-47.360
287 L X-124.753 Y-53.297 Z-47.361
288 L X-125.018 Y-53.195 Z-47.365
289 L X-125.475 Y-52.988 Z-47.372
290 L X-125.718 Y-52.857 Z-47.375
291 L X-125.929 Y-52.730 Z-47.379
292 L X-126.113 Y-52.609 Z-47.378
293 L X-126.335 Y-52.450 Z-47.381
294 L X-126.686 Y-52.161
295 L X-127.042 Y-51.815 Z-47.385
296 L X-127.192 Y-51.651 Z-47.380
297 L X-127.496 Y-51.270
298 L X-127.637 Y-51.072 Z-47.377
299 L X-127.900 Y-50.637 Z-47.373
300 L X-128.015 Y-50.421 Z-47.368
301 L X-128.135 Y-50.162 Z-47.366
302 L X-128.316 Y-49.687 Z-47.356
303 L X-128.404 Y-49.406 Z-47.353
304 L X-128.475 Y-49.130 Z-47.350
305 L X-128.529 Y-48.861 Z-47.347
306 L X-128.577 Y-48.555 Z-47.346
307 L X-128.610 Y-48.246 Z-47.344
308 L X-128.626 Y-47.932 Z-47.346
309 L X-131.853 Y-47.998 Z-49.609
310 L X-131.854 Y-47.932
311 L X-131.857 Y-38.034 Z-49.611
312 L Y41.555
313 L X-131.854 Y47.876 Z-49.609
314 L X-131.841 Y48.266
315 L X-131.812 Y48.655
316 L X-131.766 Y49.041
317 L X-131.703 Y49.422
318 L X-131.627 Y49.803
319 L X-131.426 Y50.548
320 L X-131.300 Y50.911
321 L X-131.162 Y51.271
322 L X-130.837 Y51.963 Z-49.612
323 L X-130.650 Y52.300 Z-49.611
324 L X-130.454 Y52.628 Z-49.612
325 L X-130.245 Y52.943 Z-49.611
326 L X-130.020 Y53.255
327 L X-129.784 Y53.553 Z-49.612
328 L X-129.537 Y53.841 Z-49.611
329 L X-129.274 Y54.121
330 L X-129.005 Y54.390 Z-49.612
331 L X-128.721 Y54.641 Z-49.611
332 L X-128.425 Y54.886
333 L X-128.125 Y55.118 Z-49.612
334 L X-127.812 Y55.335 Z-49.611
335 L X-127.487 Y55.540
336 L X-127.157 Y55.732 Z-49.612
337 L X-126.821 Y55.911 Z-49.609
338 L X-126.471 Y56.074
339 L X-126.118 Y56.220
340 L X-125.758 Y56.353
341 L X-125.390 Y56.471
342 L X-125.017 Y56.574
343 L X-124.643 Y56.662
344 L X-124.262 Y56.734
345 L X-123.876 Y56.788
346 L X-123.489 Y56.825
347 L X-123.102 Y56.850
348 L X-122.318 Y56.859 Z-49.611
349 L X-115.196 Y56.857
350 L X-43.172
351 L X-37.246
352 L X-36.855 Y56.849 Z-49.609
353 L X-36.467 Y56.824
354 L X-36.082 Y56.783
355 L X-35.697 Y56.727
356 L X-35.315 Y56.653
357 L X-34.941 Y56.564
358 L X-34.570 Y56.459
359 L X-34.203 Y56.339
360 L X-33.843 Y56.204
361 L X-33.491 Y56.057
362 L X-33.143 Y55.891
363 L X-32.806 Y55.711 Z-49.612
364 L X-32.478 Y55.520
365 L X-32.153 Y55.314
366 L X-31.841 Y55.093
367 L X-31.542 Y54.861 Z-49.611
368 L X-31.247 Y54.616
369 L X-30.966 Y54.360 Z-49.612
370 L X-30.434 Y53.813
371 L X-29.956 Y53.223 Z-49.611
372 L X-29.734 Y52.908
373 L X-29.523 Y52.591 Z-49.612
374 L X-29.327 Y52.265
375 L X-29.144 Y51.927
376 L X-28.978 Y51.580 Z-49.609
377 L X-28.825 Y51.230
378 L X-28.687 Y50.872
379 L X-28.562 Y50.507
380 L X-28.456 Y50.137
381 L X-28.365 Y49.761
382 L X-28.287 Y49.381
383 L X-28.230 Y48.998
384 L X-28.184 Y48.613
385 L X-28.157 Y48.224
386 L X-28.143 Y47.833
387 L Y40.321 Z-49.611
388 L Y-42.050
389 L X-28.141 Y-47.581
390 L X-28.147 Y-47.972 Z-49.609
391 L X-28.163 Y-48.361
392 L X-28.197 Y-48.750
393 L X-28.247 Y-49.136
394 L X-28.314 Y-49.517
395 L X-28.397 Y-49.894
396 L X-28.494 Y-50.270
397 L X-28.605 Y-50.638
398 L X-28.732 Y-50.999
399 L X-28.877 Y-51.357
400 L X-29.037 Y-51.707 Z-49.612
401 L X-29.209 Y-52.047
402 L X-29.395 Y-52.382 Z-49.611
403 L X-29.594 Y-52.708 Z-49.612
404 L X-30.034 Y-53.332
405 L X-30.527 Y-53.913
406 L X-30.790 Y-54.188 Z-49.611
407 L X-31.063 Y-54.456 Z-49.612
408 L X-31.347 Y-54.704
409 L X-31.646 Y-54.945 Z-49.611
410 L X-31.953 Y-55.173 Z-49.612
411 L X-32.267 Y-55.388
412 L X-32.590 Y-55.591
413 L X-32.925 Y-55.777
414 L X-33.264 Y-55.948 Z-49.611
415 L X-33.614 Y-56.109
416 L X-33.971 Y-56.253 Z-49.609
417 L X-34.331 Y-56.386
418 L X-34.699 Y-56.498
419 L X-35.073 Y-56.598
420 L X-35.450 Y-56.680
421 L X-35.831 Y-56.747
422 L X-36.217 Y-56.798
423 L X-36.605 Y-56.833
424 L X-37.385 Y-56.859 Z-49.611
425 L X-44.901 Y-56.857
426 L X-116.528
427 L X-122.850 Z-49.609
428 L X-123.240 Y-56.842
429 L X-123.628 Y-56.814
430 L X-124.015 Y-56.770
431 L X-124.396 Y-56.708
432 L X-124.777 Y-56.631
433 L X-125.153 Y-56.540
434 L X-125.523 Y-56.433
435 L X-125.886 Y-56.308
436 L X-126.246 Y-56.169
437 L X-126.595 Y-56.015 Z-49.612
438 L X-126.940 Y-55.848 Z-49.611
439 L X-127.279 Y-55.666 Z-49.612
440 L X-127.606 Y-55.469
441 L X-127.922 Y-55.259 Z-49.611
442 L X-128.235 Y-55.036 Z-49.612
443 L X-128.532 Y-54.801
444 L X-128.822 Y-54.554 Z-49.611
445 L X-129.101 Y-54.292
446 L X-129.372 Y-54.024 Z-49.612
447 L X-129.624 Y-53.741 Z-49.611
448 L X-129.870 Y-53.445
449 L X-130.103 Y-53.147 Z-49.612
450 L X-130.322 Y-52.835
451 L X-130.719 Y-52.181
452 L X-130.899 Y-51.844
453 L X-131.064 Y-51.495 Z-49.609
454 L X-131.210 Y-51.143
455 L X-131.344 Y-50.783
456 L X-131.464 Y-50.415
457 L X-131.567 Y-50.043
458 L X-131.657 Y-49.669
459 L X-131.730 Y-49.287
460 L X-131.784 Y-48.903
461 L X-131.824 Y-48.516
462 L X-131.850 Y-48.129
463 L X-131.853 Y-47.998
464 L X-128.786 Y-47.961 Z-47.686
465 L X-128.792 Y-47.498 Z-47.682
466 L X-128.781 Y-43.090 Z-47.664
467 L X-128.780 Y-30.872 Z-47.662
468 L Y35.192
469 L X-128.783 Y44.538 Z-47.669
470 L X-128.792 Y47.764 Z-47.686
471 L X-128.782 Y48.091 Z-47.685
472 L X-128.758 Y48.407
473 L X-128.721 Y48.695 Z-47.686
474 L X-128.667 Y49.004 Z-47.688
475 L X-128.600 Y49.296
476 L X-128.525 Y49.572 Z-47.696
477 L X-128.444 Y49.824
478 L X-128.339 Y50.094 Z-47.701
479 L X-128.126 Y50.561 Z-47.705
480 L X-127.988 Y50.813 Z-47.706
481 L X-127.858 Y51.029 Z-47.711
482 L X-127.734 Y51.216 Z-47.710
483 L X-127.571 Y51.443 Z-47.712
484 L X-127.272 Y51.805 Z-47.713
485 L X-127.084 Y52.005
486 L X-126.910 Y52.176 Z-47.716
487 L X-126.745 Y52.325 Z-47.711
488 L X-126.528 Y52.503
489 L X-126.147 Y52.781 Z-47.708
490 L X-125.916 Y52.927 Z-47.706
491 L X-125.693 Y53.054
492 L X-125.477 Y53.167 Z-47.703
493 L X-125.213 Y53.289 Z-47.701
494 L X-124.976 Y53.384 Z-47.697
495 L X-124.725 Y53.474 Z-47.692
496 L X-124.437 Y53.563 Z-47.689
497 L X-124.153 Y53.636 Z-47.687
498 L X-123.879 Y53.690 Z-47.685
499 L X-123.574 Y53.737
500 L X-123.257 Y53.770 Z-47.684
501 L X-122.940 Y53.787 Z-47.686
502 L X-121.585 Y53.789 Z-47.679
503 L X-117.488 Y53.781 Z-47.663
504 L X-102.465 Y53.780 Z-47.662
505 L X-50.330
506 L X-40.207 Y53.783 Z-47.669
507 L X-37.335 Y53.791 Z-47.688
508 L X-37.019 Y53.785 Z-47.685
509 L X-36.712 Y53.767 Z-47.684
510 L X-36.397 Y53.733 Z-47.685
511 L X-36.085 Y53.682
512 L X-35.810 Y53.627 Z-47.687
513 L X-35.538 Y53.557 Z-47.689
514 L X-35.252 Y53.466 Z-47.692
515 L X-34.991 Y53.371 Z-47.696
516 L X-34.767 Y53.279 Z-47.700
517 L X-34.504 Y53.157 Z-47.701
518 L X-34.072 Y52.918 Z-47.706
519 L X-33.837 Y52.770 Z-47.708
520 L X-33.454 Y52.487 Z-47.710
521 L X-33.243 Y52.313
522 L X-32.904 Y51.991
523 L X-32.715 Y51.790 Z-47.711
524 L X-32.419 Y51.427 Z-47.709
525 L X-32.256 Y51.199 Z-47.706
526 L X-31.999 Y50.789 Z-47.704
527 L X-31.865 Y50.541 Z-47.702
528 L X-31.648 Y50.059 Z-47.698
529 L X-31.550 Y49.801 Z-47.693
530 L X-31.465 Y49.534 Z-47.692
531 L X-31.392 Y49.261 Z-47.688
532 L X-31.329 Y48.973 Z-47.685
533 L X-31.275 Y48.662
534 L X-31.240 Y48.365 Z-47.683
535 L X-31.218 Y48.056
536 L X-31.207 Y47.395 Z-47.686
537 L X-31.219 Y43.369 Z-47.665
538 L X-31.220 Y29.580 Z-47.662
539 L Y-34.495
540 L X-31.217 Y-44.628 Z-47.668
541 L X-31.211 Y-47.834 Z-47.687
542 L X-31.223 Y-48.164 Z-47.684
543 L X-31.250 Y-48.480
544 L X-31.291 Y-48.776 Z-47.685
545 L X-31.346 Y-49.066 Z-47.687
546 L X-31.418 Y-49.366 Z-47.689
547 L X-31.496 Y-49.636 Z-47.695
548 L X-31.579 Y-49.884 Z-47.699
549 L X-31.685 Y-50.156 Z-47.700
550 L X-31.912 Y-50.633 Z-47.708
551 L X-32.037 Y-50.860
552 L X-32.173 Y-51.080 Z-47.713
553 L X-32.463 Y-51.491 Z-47.715
554 L X-32.784 Y-51.869 Z-47.719
555 L X-32.951 Y-52.044 Z-47.716
556 L X-33.135 Y-52.221 Z-47.719
557 L X-33.509 Y-52.536 Z-47.715
558 L X-33.916 Y-52.826
559 L X-34.126 Y-52.956 Z-47.711
560 L X-34.365 Y-53.088 Z-47.709
561 L X-34.828 Y-53.309 Z-47.701
562 L X-35.089 Y-53.411 Z-47.698
563 L X-35.350 Y-53.501 Z-47.699
564 L X-35.611 Y-53.577 Z-47.692
565 L X-35.907 Y-53.650 Z-47.690
566 L X-36.193 Y-53.705 Z-47.686
567 L X-36.485 Y-53.745 Z-47.684
568 L X-36.808 Y-53.775 Z-47.685
569 L X-37.128 Y-53.789 Z-47.686
570 L X-38.505 Z-47.680
571 L X-42.607 Y-53.781 Z-47.663
572 L X-57.235 Y-53.780 Z-47.662
573 L X-110.562
574 L X-119.885 Y-53.784 Z-47.670
575 L X-122.413 Y-53.794 Z-47.688
576 L X-123.068 Y-53.783 Z-47.685
577 L X-123.385 Y-53.760 Z-47.686
578 L X-123.677 Y-53.724
579 L X-123.988 Y-53.669 Z-47.687
580 L X-124.276 Y-53.605 Z-47.691
581 L X-124.553 Y-53.531 Z-47.696
582 L X-124.810 Y-53.448
583 L X-125.080 Y-53.345 Z-47.700
584 L X-125.549 Y-53.132 Z-47.705
585 L X-125.796 Y-52.999 Z-47.708
586 L X-126.013 Y-52.868 Z-47.712
587 L X-126.205 Y-52.743 Z-47.711
588 L X-126.431 Y-52.580 Z-47.713
589 L X-126.794 Y-52.282
590 L X-127.160 Y-51.927 Z-47.717
591 L X-127.315 Y-51.757 Z-47.712
592 L X-127.628 Y-51.365
593 L X-127.773 Y-51.161 Z-47.710
594 L X-128.042 Y-50.715 Z-47.706
595 L X-128.160 Y-50.493 Z-47.702
596 L X-128.282 Y-50.229 Z-47.701
597 L X-128.377 Y-49.996 Z-47.697
598 L X-128.468 Y-49.742 Z-47.692
599 L X-128.558 Y-49.457 Z-47.690
600 L X-128.631 Y-49.176 Z-47.687
601 L X-128.685 Y-48.902 Z-47.686
602 L X-128.735 Y-48.592 Z-47.685
603 L X-128.768 Y-48.279 Z-47.684
604 L X-128.786 Y-47.961 Z-47.686
605 L X-131.476 Y-47.950 Z-49.576
606 L X-131.475 Y-47.878
607 L X-131.481 Y-47.104 Z-49.578
608 L X-131.477 Y-40.415 Z-49.577
609 L Y40.756
610 L X-131.482 Y47.436 Z-49.578
611 L X-131.463 Y48.204 Z-49.575
612 L X-131.436 Y48.585 Z-49.576
613 L X-131.393 Y48.962 Z-49.575
614 L X-131.332 Y49.331
615 L X-131.259 Y49.703
616 L X-131.065 Y50.427 Z-49.576
617 L X-130.944 Y50.775 Z-49.575
618 L X-130.811 Y51.124 Z-49.576
619 L X-130.498 Y51.788 Z-49.577
620 L X-130.318 Y52.114 Z-49.576
621 L X-130.131 Y52.428 Z-49.577
622 L X-129.931 Y52.727
623 L X-129.715 Y53.029
624 L X-129.490 Y53.312
625 L X-129.254 Y53.587
626 L X-129.001 Y53.857
627 L X-128.744 Y54.114
628 L X-128.475 Y54.352 Z-49.576
629 L X-128.188 Y54.589 Z-49.577
630 L X-127.904 Y54.809
631 L X-127.604 Y55.016
632 L X-127.291 Y55.214
633 L X-126.974 Y55.397
634 L X-126.654 Y55.570 Z-49.576
635 L X-126.314 Y55.728
636 L X-125.976 Y55.867
637 L X-125.630 Y55.994 Z-49.575
638 L X-125.271 Y56.109
639 L X-124.910 Y56.208
640 L X-124.548 Y56.292
641 L X-124.176 Y56.361
642 L X-123.799 Y56.413
643 L X-123.044 Y56.475 Z-49.576
644 L X-122.272 Y56.481 Z-49.578
645 L X-115.985 Y56.477 Z-49.577
646 L X-43.576
647 L X-37.299 Y56.480 Z-49.578
648 L X-36.914 Y56.475 Z-49.577
649 L X-36.536 Y56.448 Z-49.576
650 L X-36.160 Y56.408 Z-49.575
651 L X-35.784 Y56.354
652 L X-35.411 Y56.283
653 L X-35.049 Y56.198
654 L X-34.691 Y56.098
655 L X-34.333 Y55.981
656 L X-33.986 Y55.851
657 L X-33.650 Y55.712 Z-49.576
658 L X-33.313 Y55.550 Z-49.575
659 L X-32.990 Y55.377 Z-49.577
660 L X-32.677 Y55.195
661 L X-32.363 Y54.997
662 L X-32.064 Y54.784
663 L X-31.781 Y54.565
664 L X-31.496 Y54.329
665 L X-31.228 Y54.084
666 L X-30.718 Y53.560
667 L X-30.263 Y52.998
668 L X-30.049 Y52.695 Z-49.578
669 L X-29.847 Y52.391 Z-49.577
670 L X-29.660 Y52.081
671 L X-29.483 Y51.754
672 L X-29.323 Y51.420 Z-49.575
673 L X-29.176 Y51.084
674 L X-29.044 Y50.738
675 L X-28.923 Y50.386 Z-49.576
676 L X-28.822 Y50.028 Z-49.575
677 L X-28.734 Y49.663
678 L X-28.658 Y49.291
679 L X-28.604 Y48.919
680 L X-28.560 Y48.544 Z-49.576
681 L X-28.535 Y48.162
682 L X-28.519 Y47.780
683 L X-28.523 Y41.109 Z-49.577
684 L Y-41.249
685 L X-28.518 Y-47.531 Z-49.578
686 L X-28.525 Y-47.916 Z-49.576
687 L X-28.541 Y-48.296 Z-49.575
688 L X-28.573 Y-48.677
689 L X-28.621 Y-49.054
690 L X-28.684 Y-49.424
691 L X-28.764 Y-49.791
692 L X-28.858 Y-50.157
693 L X-28.965 Y-50.513 Z-49.576
694 L X-29.086 Y-50.860
695 L X-29.227 Y-51.208 Z-49.575
696 L X-29.382 Y-51.545 Z-49.577
697 L X-29.546 Y-51.871
698 L X-29.724 Y-52.192
699 L X-29.915 Y-52.505
700 L X-30.337 Y-53.102
701 L X-30.808 Y-53.658
702 L X-31.060 Y-53.921
703 L X-31.321 Y-54.177 Z-49.578
704 L X-31.591 Y-54.413 Z-49.577
705 L X-31.878 Y-54.645
706 L X-32.173 Y-54.863
707 L X-32.473 Y-55.069
708 L X-32.782 Y-55.262
709 L X-33.105 Y-55.442
710 L X-33.427 Y-55.604
711 L X-33.765 Y-55.760 Z-49.576
712 L X-34.110 Y-55.899 Z-49.575
713 L X-34.458 Y-56.027 Z-49.576
714 L X-34.812 Y-56.134 Z-49.575
715 L X-35.177 Y-56.232
716 L X-35.543 Y-56.309
717 L X-35.912 Y-56.373
718 L X-36.291 Y-56.422
719 L X-36.670 Y-56.456
720 L X-37.435 Y-56.482 Z-49.578
721 L X-44.113 Y-56.477 Z-49.577
722 L X-115.729
723 L X-122.796 Y-56.481 Z-49.576
724 L X-123.559 Y-56.439
725 L X-123.937 Y-56.396 Z-49.575
726 L X-124.307 Y-56.337
727 L X-124.679 Y-56.262
728 L X-125.043 Y-56.174
729 L X-125.403 Y-56.072 Z-49.576
730 L X-125.752 Y-55.952 Z-49.575
731 L X-126.101 Y-55.817
732 L X-126.435 Y-55.670 Z-49.577
733 L X-126.766 Y-55.509
734 L X-127.094 Y-55.333
735 L X-127.407 Y-55.144
736 L X-127.708 Y-54.945
737 L X-128.010 Y-54.730
738 L X-128.292 Y-54.507
739 L X-128.569 Y-54.271
740 L X-128.838 Y-54.019
741 L X-129.096 Y-53.763
742 L X-129.336 Y-53.493 Z-49.576
743 L X-129.574 Y-53.208 Z-49.577
744 L X-129.794 Y-52.925
745 L X-130.004 Y-52.626
746 L X-130.385 Y-51.998
747 L X-130.557 Y-51.675
748 L X-130.718 Y-51.337 Z-49.576
749 L X-130.857 Y-51.000 Z-49.575
750 L X-130.985 Y-50.653
751 L X-131.102 Y-50.296
752 L X-131.202 Y-49.935
753 L X-131.287 Y-49.574
754 L X-131.357 Y-49.201
755 L X-131.409 Y-48.825
756 L X-131.448 Y-48.447 Z-49.576
757 L X-131.476 Y-48.071 Z-49.577
758 L Y-47.950 Z-49.576
759 L X-128.983 Y-47.860 Z-48.011
760 L X-128.987 Y-47.683 Z-48.014
761 L X-128.985 Y-47.525 Z-48.007
762 L X-128.974 Y-41.555 Z-47.992
763 L Y-29.280
764 L Y35.590 Z-47.991
765 L X-128.978 Y44.923 Z-47.999
766 L X-128.987 Y47.116 Z-48.012
767 L X-128.983 Y47.795 Z-48.010
768 L X-128.975 Y48.126 Z-48.006
769 L X-128.949 Y48.447 Z-48.007
770 L X-128.909 Y48.741 Z-48.006
771 L X-128.853 Y49.054 Z-48.009
772 L X-128.709 Y49.633 Z-48.016
773 L X-128.518 Y50.168 Z-48.020
774 L X-128.294 Y50.648 Z-48.023
775 L X-128.154 Y50.906 Z-48.024
776 L X-128.020 Y51.128 Z-48.028
777 L X-127.891 Y51.324
778 L X-127.724 Y51.555 Z-48.029
779 L X-127.413 Y51.932 Z-48.030
780 L X-127.220 Y52.137
781 L X-127.040 Y52.314 Z-48.033
782 L X-126.868 Y52.469 Z-48.028
783 L X-126.646 Y52.652
784 L X-126.251 Y52.940 Z-48.026
785 L X-126.013 Y53.089 Z-48.025
786 L X-125.562 Y53.340 Z-48.022
787 L X-125.292 Y53.465 Z-48.019
788 L X-124.790 Y53.653 Z-48.013
789 L X-124.496 Y53.744 Z-48.011
790 L X-124.207 Y53.819 Z-48.009
791 L X-123.927 Y53.877 Z-48.006
792 L X-123.618 Y53.926
793 L X-123.296 Y53.961
794 L X-122.975 Y53.979 Z-48.007
795 L X-122.323 Y53.986 Z-48.012
796 L X-117.877 Y53.975 Z-47.993
797 L X-103.659 Y53.974 Z-47.992
798 L X-49.932 Z-47.991
799 L X-40.194 Y53.977 Z-47.997
800 L X-37.304 Y53.987 Z-48.014
801 L X-36.984 Y53.979 Z-48.008
802 L X-36.672 Y53.958 Z-48.005
803 L X-36.353 Y53.922 Z-48.006
804 L X-36.037 Y53.870
805 L X-35.756 Y53.809 Z-48.009
806 L X-35.478 Y53.737 Z-48.010
807 L X-35.186 Y53.645 Z-48.013
808 L X-34.686 Y53.455 Z-48.019
809 L X-34.419 Y53.328 Z-48.020
810 L X-33.973 Y53.080 Z-48.024
811 L X-33.732 Y52.929 Z-48.025
812 L X-33.335 Y52.635 Z-48.027
813 L X-33.118 Y52.457 Z-48.028
814 L X-32.767 Y52.121
815 L X-32.573 Y51.916 Z-48.029
816 L X-32.266 Y51.538 Z-48.026
817 L X-32.099 Y51.305 Z-48.024
818 L X-31.833 Y50.881 Z-48.023
819 L X-31.696 Y50.627 Z-48.021
820 L X-31.472 Y50.132 Z-48.019
821 L X-31.372 Y49.867 Z-48.013
822 L X-31.282 Y49.595 Z-48.012
823 L X-31.207 Y49.316 Z-48.009
824 L X-31.142 Y49.022 Z-48.006
825 L X-31.086 Y48.707
826 L X-31.049 Y48.405 Z-48.004
827 L X-31.025 Y48.092 Z-48.005
828 L X-31.012 Y47.423 Z-48.013
829 L X-31.025 Y43.377 Z-47.994
830 L X-31.026 Y25.202 Z-47.992
831 L Y-34.893 Z-47.991
832 L X-31.022 Y-45.013 Z-47.998
833 L X-31.015 Y-47.543 Z-48.011
834 L X-31.016 Y-47.867 Z-48.009
835 L X-31.031 Y-48.201 Z-48.006
836 L X-31.060 Y-48.522
837 L X-31.103 Y-48.823
838 L X-31.162 Y-49.117 Z-48.008
839 L X-31.236 Y-49.422 Z-48.011
840 L X-31.314 Y-49.699 Z-48.015
841 L X-31.399 Y-49.954 Z-48.017
842 L X-31.510 Y-50.231 Z-48.020
843 L X-31.744 Y-50.721 Z-48.026
844 L X-31.873 Y-50.955
845 L X-32.013 Y-51.182 Z-48.030
846 L X-32.312 Y-51.605 Z-48.032
847 L X-32.643 Y-51.997 Z-48.035
848 L X-32.816 Y-52.178 Z-48.032
849 L X-33.006 Y-52.360 Z-48.036
850 L X-33.393 Y-52.687 Z-48.032
851 L X-33.814 Y-52.986
852 L X-34.031 Y-53.120 Z-48.028
853 L X-34.275 Y-53.255 Z-48.027
854 L X-34.753 Y-53.483 Z-48.020
855 L X-35.286 Y-53.684 Z-48.018
856 L X-35.854 Y-53.836 Z-48.010
857 L X-36.146 Y-53.892 Z-48.007
858 L X-36.444 Y-53.935 Z-48.005
859 L X-36.771 Y-53.967 Z-48.006
860 L X-37.095 Y-53.982 Z-48.008
861 L X-37.764 Y-53.987 Z-48.013
862 L X-41.455 Y-53.976 Z-47.994
863 L X-118.772 Z-47.995
864 L X-122.440 Y-53.989 Z-48.014
865 L X-123.104 Y-53.976 Z-48.007
866 L X-123.425 Y-53.951
867 L X-123.722 Y-53.912 Z-48.006
868 L X-124.037 Y-53.856 Z-48.008
869 L X-124.331 Y-53.790 Z-48.011
870 L X-124.614 Y-53.715 Z-48.016
871 L X-124.877 Y-53.626
872 L X-125.153 Y-53.521 Z-48.020
873 L X-125.636 Y-53.301 Z-48.023
874 L X-125.889 Y-53.165 Z-48.026
875 L X-126.113 Y-53.030 Z-48.029
876 L X-126.312 Y-52.900 Z-48.028
877 L X-126.544 Y-52.733 Z-48.030
878 L X-126.921 Y-52.424
879 L X-127.298 Y-52.058 Z-48.034
880 L X-127.459 Y-51.880 Z-48.029
881 L X-127.782 Y-51.476 Z-48.030
882 L X-127.932 Y-51.265 Z-48.027
883 L X-128.209 Y-50.806 Z-48.024
884 L X-128.330 Y-50.577 Z-48.021
885 L X-128.458 Y-50.309 Z-48.020
886 L X-128.647 Y-49.807 Z-48.013
887 L X-128.739 Y-49.517 Z-48.011
888 L X-128.813 Y-49.230 Z-48.009
889 L X-128.873 Y-48.950 Z-48.007
890 L X-128.924 Y-48.636 Z-48.006
891 L X-128.958 Y-48.318 Z-48.005
892 L X-128.979 Y-47.997 Z-48.008
893 L X-128.983 Y-47.860 Z-48.011
894 L X-131.102 Y-47.825 Z-49.502
895 L X-131.110 Y-47.447 Z-49.504
896 L X-131.104 Y-39.222 Z-49.502
897 L Y27.235
898 L X-131.109 Y46.618 Z-49.504
899 L X-131.111 Y47.388
900 L X-131.090 Y48.142 Z-49.505
901 L X-131.065 Y48.516
902 L X-131.024 Y48.885
903 L X-130.965 Y49.242 Z-49.504
904 L X-130.895 Y49.605
905 L X-130.709 Y50.307 Z-49.505
906 L X-130.593 Y50.642 Z-49.504
907 L X-130.464 Y50.980 Z-49.506
908 L X-130.165 Y51.615 Z-49.504
909 L X-129.990 Y51.931
910 L X-129.811 Y52.232 Z-49.505
911 L X-129.623 Y52.515 Z-49.504
912 L X-129.414 Y52.806
913 L X-129.200 Y53.075
914 L X-128.976 Y53.336
915 L X-128.731 Y53.597
916 L X-128.486 Y53.842 Z-49.505
917 L X-128.231 Y54.067 Z-49.504
918 L X-127.955 Y54.296
919 L X-127.685 Y54.504 Z-49.505
920 L X-127.399 Y54.702 Z-49.504
921 L X-127.098 Y54.892
922 L X-126.794 Y55.068
923 L X-126.489 Y55.233 Z-49.505
924 L X-126.160 Y55.385
925 L X-125.835 Y55.518
926 L X-125.502 Y55.640 Z-49.504
927 L X-125.153 Y55.751 Z-49.503
928 L X-124.803 Y55.847 Z-49.504
929 L X-124.454 Y55.927 Z-49.505
930 L X-124.092 Y55.993
931 L X-123.723 Y56.042 Z-49.504
932 L X-122.987 Y56.104 Z-49.507
933 L X-122.227 Y56.110 Z-49.504
934 L X-115.188 Y56.104 Z-49.502
935 L X-43.978
936 L X-37.350 Y56.109 Z-49.504
937 L X-36.972 Y56.105 Z-49.508
938 L X-36.603 Y56.076 Z-49.505
939 L X-36.237 Y56.038 Z-49.504
940 L X-35.870 Y55.987
941 L X-35.506 Y55.918
942 L X-35.156 Y55.836
943 L X-34.810 Y55.741
944 L X-34.462 Y55.627
945 L X-34.127 Y55.503 Z-49.505
946 L X-33.807 Y55.370
947 L X-33.480 Y55.214 Z-49.504
948 L X-33.171 Y55.048
949 L X-32.873 Y54.875
950 L X-32.570 Y54.684
951 L X-32.284 Y54.480 Z-49.505
952 L X-32.016 Y54.273 Z-49.504
953 L X-31.741 Y54.046
954 L X-31.487 Y53.812 Z-49.505
955 L X-30.999 Y53.311 Z-49.504
956 L X-30.566 Y52.778
957 L X-30.359 Y52.485 Z-49.503
958 L X-30.167 Y52.195 Z-49.504
959 L X-29.989 Y51.899
960 L X-29.818 Y51.583
961 L X-29.664 Y51.263 Z-49.505
962 L X-29.523 Y50.941
963 L X-29.396 Y50.606 Z-49.504
964 L X-29.280 Y50.266 Z-49.505
965 L X-29.183 Y49.920
966 L X-29.099 Y49.566 Z-49.504
967 L X-29.026 Y49.203
968 L X-28.973 Y48.842
969 L X-28.932 Y48.476 Z-49.505
970 L X-28.891 Y47.726 Z-49.506
971 L X-28.896 Y38.727 Z-49.502
972 L Y-40.848
973 L X-28.890 Y-47.482 Z-49.504
974 L X-28.914 Y-48.231 Z-49.505
975 L X-28.944 Y-48.605
976 L X-28.990 Y-48.974
977 L X-29.050 Y-49.333 Z-49.504
978 L X-29.127 Y-49.689 Z-49.503
979 L X-29.218 Y-50.046 Z-49.504
980 L X-29.320 Y-50.390 Z-49.505
981 L X-29.436 Y-50.723
982 L X-29.572 Y-51.060
983 L X-29.722 Y-51.385 Z-49.504
984 L X-29.879 Y-51.697
985 L X-30.049 Y-52.005
986 L X-30.233 Y-52.305 Z-49.505
987 L X-30.636 Y-52.876 Z-49.504
988 L X-31.086 Y-53.407 Z-49.505
989 L X-31.325 Y-53.657 Z-49.504
990 L X-31.576 Y-53.902 Z-49.506
991 L X-31.831 Y-54.125 Z-49.505
992 L X-32.107 Y-54.349 Z-49.504
993 L X-32.389 Y-54.557 Z-49.505
994 L X-32.676 Y-54.754
995 L X-32.971 Y-54.938 Z-49.504
996 L X-33.282 Y-55.111 Z-49.505
997 L X-33.588 Y-55.265 Z-49.504
998 L X-33.915 Y-55.415 Z-49.503
999 L X-34.248 Y-55.549 Z-49.504
1000 L X-34.583 Y-55.673 Z-49.505
1001 L X-34.924 Y-55.775 Z-49.504
1002 L X-35.279 Y-55.869
1003 L X-35.634 Y-55.944
1004 L X-35.993 Y-56.004
1005 L X-36.363 Y-56.051
1006 L X-36.734 Y-56.083
1007 L X-37.484 Y-56.111
1008 L X-46.495 Y-56.104 Z-49.502
1009 L X-115.328
1010 L X-122.743 Y-56.109 Z-49.506
1011 L X-123.490 Y-56.067 Z-49.505
1012 L X-123.859 Y-56.027
1013 L X-124.218 Y-55.970 Z-49.503
1014 L X-124.582 Y-55.898 Z-49.504
1015 L X-124.936 Y-55.814 Z-49.505
1016 L X-125.283 Y-55.716
1017 L X-125.620 Y-55.600 Z-49.504
1018 L X-125.957 Y-55.470 Z-49.505
1019 L X-126.277 Y-55.329 Z-49.504
1020 L X-126.595 Y-55.175
1021 L X-126.911 Y-55.005 Z-49.505
1022 L X-127.211 Y-54.824
1023 L X-127.496 Y-54.636 Z-49.504
1024 L X-127.788 Y-54.428
1025 L X-128.055 Y-54.216
1026 L X-128.320 Y-53.991
1027 L X-128.578 Y-53.749
1028 L X-128.824 Y-53.505 Z-49.505
1029 L X-129.052 Y-53.249 Z-49.504
1030 L X-129.281 Y-52.974
1031 L X-129.490 Y-52.706 Z-49.505
1032 L X-129.691 Y-52.420 Z-49.504
1033 L X-130.056 Y-51.817
1034 L X-130.220 Y-51.509
1035 L X-130.376 Y-51.182 Z-49.505
1036 L X-130.509 Y-50.859
1037 L X-130.632 Y-50.525 Z-49.504
1038 L X-130.744 Y-50.178
1039 L X-130.840 Y-49.829
1040 L X-130.922 Y-49.479 Z-49.505
1041 L X-130.989 Y-49.116 Z-49.504
1042 L X-131.039 Y-48.749
1043 L X-131.106 Y-48.013 Z-49.508
1044 L X-131.102 Y-47.825 Z-49.502
1045 L X-129.216 Y-47.718 Z-48.318
1046 L X-129.210 Y-47.557 Z-48.310
1047 L X-129.213 Y-47.209 Z-48.314
1048 L X-129.201 Y-42.335 Z-48.300
1049 L Y-30.076 Z-48.299
1050 L Y35.987
1051 L X-129.206 Y45.311 Z-48.306
1052 L X-129.215 Y47.145 Z-48.316
1053 L X-129.208 Y47.832 Z-48.311
1054 L X-129.196 Y48.168 Z-48.308
1055 L X-129.168 Y48.494
1056 L X-129.126 Y48.793 Z-48.307
1057 L X-129.068 Y49.112 Z-48.309
1058 L X-128.996 Y49.415
1059 L X-128.919 Y49.704 Z-48.316
1060 L X-128.830 Y49.971 Z-48.315
1061 L X-128.723 Y50.254 Z-48.319
1062 L X-128.492 Y50.751 Z-48.320
1063 L X-128.348 Y51.014
1064 L X-128.209 Y51.245 Z-48.324
1065 L X-128.074 Y51.450 Z-48.323
1066 L X-127.903 Y51.688 Z-48.324
1067 L X-127.579 Y52.080 Z-48.325
1068 L X-127.380 Y52.292
1069 L X-127.194 Y52.476 Z-48.328
1070 L X-127.012 Y52.638 Z-48.324
1071 L X-126.785 Y52.826
1072 L X-126.372 Y53.127 Z-48.322
1073 L X-126.128 Y53.280 Z-48.321
1074 L X-125.660 Y53.540 Z-48.320
1075 L X-125.384 Y53.667 Z-48.318
1076 L X-125.131 Y53.768 Z-48.315
1077 L X-124.865 Y53.863 Z-48.312
1078 L X-124.565 Y53.957 Z-48.309
1079 L X-124.270 Y54.034
1080 L X-123.983 Y54.093 Z-48.308
1081 L X-123.668 Y54.144
1082 L X-123.341 Y54.181 Z-48.307
1083 L X-122.696 Y54.215 Z-48.315
1084 L X-117.885 Y54.202 Z-48.300
1085 L X-40.932 Y54.203 Z-48.302
1086 L X-37.268 Y54.216 Z-48.318
1087 L X-36.943 Y54.202 Z-48.310
1088 L X-36.626 Y54.177 Z-48.307
1089 L X-36.302 Y54.140
1090 L X-35.981 Y54.085
1091 L X-35.693 Y54.024 Z-48.309
1092 L X-35.407 Y53.950
1093 L X-35.110 Y53.855 Z-48.311
1094 L X-34.836 Y53.755 Z-48.315
1095 L X-34.593 Y53.656 Z-48.318
1096 L X-34.320 Y53.528
1097 L X-33.856 Y53.270 Z-48.320
1098 L X-33.609 Y53.115 Z-48.321
1099 L X-33.195 Y52.809 Z-48.323
1100 L X-32.973 Y52.625
1101 L X-32.606 Y52.275
1102 L X-32.406 Y52.064 Z-48.324
1103 L X-32.086 Y51.670 Z-48.322
1104 L X-31.914 Y51.430 Z-48.320
1105 L X-31.770 Y51.208 Z-48.321
1106 L X-31.638 Y50.989 Z-48.319
1107 L X-31.497 Y50.728 Z-48.318
1108 L X-31.374 Y50.470 Z-48.317
1109 L X-31.265 Y50.218
1110 L X-31.163 Y49.946 Z-48.312
1111 L X-31.071 Y49.666
1112 L X-30.994 Y49.380 Z-48.309
1113 L X-30.927 Y49.080 Z-48.307
1114 L X-30.869 Y48.759 Z-48.308
1115 L X-30.830 Y48.451 Z-48.306
1116 L X-30.803 Y48.132 Z-48.307
1117 L X-30.790 Y47.796 Z-48.308
1118 L X-30.785 Y47.455 Z-48.316
1119 L X-30.799 Y42.620 Z-48.300
1120 L X-30.797 Y-44.279 Z-48.303
1121 L X-30.785 Y-47.233 Z-48.316
1122 L X-30.793 Y-47.906 Z-48.310
1123 L X-30.811 Y-48.244 Z-48.308
1124 L X-30.842 Y-48.569
1125 L X-30.886 Y-48.876 Z-48.307
1126 L X-30.947 Y-49.178
1127 L X-31.023 Y-49.489 Z-48.310
1128 L X-31.104 Y-49.772 Z-48.315
1129 L X-31.193 Y-50.035 Z-48.317
1130 L X-31.305 Y-50.319
1131 L X-31.546 Y-50.825 Z-48.322
1132 L X-31.680 Y-51.066
1133 L X-31.824 Y-51.301 Z-48.326
1134 L X-32.134 Y-51.740 Z-48.327
1135 L X-32.478 Y-52.146 Z-48.330
1136 L X-32.658 Y-52.335 Z-48.327
1137 L X-32.855 Y-52.524 Z-48.330
1138 L X-33.256 Y-52.863 Z-48.326
1139 L X-33.693 Y-53.173 Z-48.327
1140 L X-33.918 Y-53.313 Z-48.324
1141 L X-34.170 Y-53.452 Z-48.323
1142 L X-34.664 Y-53.688 Z-48.316
1143 L X-34.937 Y-53.796
1144 L X-35.212 Y-53.893 Z-48.317
1145 L X-35.487 Y-53.972 Z-48.312
1146 L X-35.793 Y-54.050 Z-48.311
1147 L X-36.092 Y-54.108 Z-48.308
1148 L X-36.396 Y-54.152 Z-48.307
1149 L X-36.728 Y-54.187 Z-48.308
1150 L X-37.057 Y-54.205 Z-48.310
1151 L X-37.733 Y-54.215 Z-48.317
1152 L X-41.827 Y-54.202 Z-48.301
1153 L X-119.161 Y-54.204 Z-48.303
1154 L X-122.473 Y-54.216 Z-48.317
1155 L X-123.145 Y-54.198 Z-48.309
1156 L X-123.471 Y-54.170
1157 L X-123.774 Y-54.128 Z-48.307
1158 L X-124.095 Y-54.071 Z-48.308
1159 L X-124.395 Y-54.003 Z-48.311
1160 L X-124.685 Y-53.925 Z-48.315
1161 L X-124.955 Y-53.836 Z-48.314
1162 L X-125.238 Y-53.728 Z-48.318
1163 L X-125.737 Y-53.500 Z-48.320
1164 L X-125.997 Y-53.360 Z-48.322
1165 L X-126.229 Y-53.220 Z-48.325
1166 L X-126.437 Y-53.084 Z-48.323
1167 L X-126.675 Y-52.913 Z-48.325
1168 L X-127.069 Y-52.590
1169 L X-127.460 Y-52.211 Z-48.328
1170 L X-127.628 Y-52.025 Z-48.324
1171 L X-127.963 Y-51.606 Z-48.325
1172 L X-128.118 Y-51.388 Z-48.323
1173 L X-128.404 Y-50.913 Z-48.321
1174 L X-128.530 Y-50.676 Z-48.318
1175 L X-128.660 Y-50.401 Z-48.319
1176 L X-128.761 Y-50.151 Z-48.316
1177 L X-128.857 Y-49.883 Z-48.312
1178 L X-128.952 Y-49.587 Z-48.310
1179 L X-129.028 Y-49.293 Z-48.309
1180 L X-129.088 Y-49.006 Z-48.308
1181 L X-129.142 Y-48.686
1182 L X-129.178 Y-48.364 Z-48.306
1183 L X-129.202 Y-48.037 Z-48.310
1184 L X-129.216 Y-47.718 Z-48.318
1185 L X-130.739 Y-47.770 Z-49.390
1186 L X-130.747 Y-47.401 Z-49.396
1187 L X-130.739 Y-40.011 Z-49.393
1188 L X-130.742 Y45.429 Z-49.395
1189 L X-130.748 Y47.342 Z-49.397
1190 L X-130.727 Y48.083 Z-49.391
1191 L X-130.704 Y48.449
1192 L X-130.665 Y48.809
1193 L X-130.609 Y49.155 Z-49.388
1194 L X-130.541 Y49.510 Z-49.390
1195 L X-130.362 Y50.190 Z-49.392
1196 L X-130.252 Y50.512 Z-49.390
1197 L X-130.127 Y50.839 Z-49.392
1198 L X-129.841 Y51.448 Z-49.389
1199 L X-129.672 Y51.754 Z-49.388
1200 L X-129.501 Y52.041 Z-49.389
1201 L X-129.323 Y52.309
1202 L X-129.121 Y52.590
1203 L X-128.918 Y52.845
1204 L X-128.705 Y53.093
1205 L X-128.470 Y53.344
1206 L X-128.236 Y53.577 Z-49.390
1207 L X-127.996 Y53.791 Z-49.389
1208 L X-127.729 Y54.011
1209 L X-127.473 Y54.208 Z-49.390
1210 L X-127.201 Y54.397 Z-49.389
1211 L X-126.910 Y54.580 Z-49.388
1212 L X-126.328 Y54.905 Z-49.392
1213 L X-126.010 Y55.053 Z-49.391
1214 L X-125.699 Y55.180
1215 L X-125.379 Y55.296 Z-49.390
1216 L X-125.040 Y55.403 Z-49.389
1217 L X-124.700 Y55.496 Z-49.390
1218 L X-124.363 Y55.572
1219 L X-124.010 Y55.636
1220 L X-123.649 Y55.682 Z-49.389
1221 L X-122.931 Y55.743 Z-49.395
1222 L X-115.579 Y55.739 Z-49.393
1223 L X-47.149
1224 L X-37.028 Y55.745 Z-49.397
1225 L X-36.313 Y55.678 Z-49.389
1226 L X-35.954 Y55.629 Z-49.390
1227 L X-35.598 Y55.563
1228 L X-35.260 Y55.485
1229 L X-34.926 Y55.394 Z-49.389
1230 L X-34.588 Y55.284 Z-49.390
1231 L X-34.264 Y55.165 Z-49.391
1232 L X-33.959 Y55.039 Z-49.392
1233 L X-33.643 Y54.888 Z-49.390
1234 L X-33.347 Y54.729 Z-49.388
1235 L X-33.063 Y54.564 Z-49.389
1236 L X-32.771 Y54.380
1237 L X-32.497 Y54.185
1238 L X-32.244 Y53.990
1239 L X-31.980 Y53.771
1240 L X-31.738 Y53.549
1241 L X-31.271 Y53.070
1242 L X-30.860 Y52.563
1243 L X-30.660 Y52.280 Z-49.388
1244 L X-30.477 Y52.004 Z-49.389
1245 L X-30.308 Y51.723
1246 L X-30.143 Y51.417 Z-49.388
1247 L X-29.995 Y51.109 Z-49.391
1248 L X-29.861 Y50.801
1249 L X-29.739 Y50.478 Z-49.389
1250 L X-29.627 Y50.150 Z-49.391
1251 L X-29.534 Y49.816 Z-49.390
1252 L X-29.453 Y49.472 Z-49.389
1253 L X-29.382 Y49.117
1254 L X-29.332 Y48.766
1255 L X-29.293 Y48.409 Z-49.391
1256 L X-29.254 Y47.674 Z-49.396
1257 L X-29.261 Y36.741 Z-49.393
1258 L Y-37.279
1259 L X-29.253 Y-47.435 Z-49.396
1260 L X-29.276 Y-48.168 Z-49.391
1261 L X-29.305 Y-48.535
1262 L X-29.348 Y-48.895 Z-49.390
1263 L X-29.405 Y-49.245
1264 L X-29.480 Y-49.590 Z-49.388
1265 L X-29.568 Y-49.938 Z-49.389
1266 L X-29.666 Y-50.270 Z-49.391
1267 L X-29.776 Y-50.590
1268 L X-29.907 Y-50.916
1269 L X-30.052 Y-51.230 Z-49.388
1270 L X-30.202 Y-51.528 Z-49.389
1271 L X-30.365 Y-51.823 Z-49.388
1272 L X-30.541 Y-52.111 Z-49.390
1273 L X-30.926 Y-52.656
1274 L X-31.355 Y-53.163
1275 L X-31.583 Y-53.401 Z-49.389
1276 L X-31.824 Y-53.635 Z-49.393
1277 L X-32.064 Y-53.846 Z-49.390
1278 L X-32.330 Y-54.061 Z-49.389
1279 L X-32.600 Y-54.260 Z-49.390
1280 L X-32.872 Y-54.448
1281 L X-33.154 Y-54.623 Z-49.389
1282 L X-33.454 Y-54.790
1283 L X-33.744 Y-54.936 Z-49.388
1284 L X-34.060 Y-55.081 Z-49.387
1285 L X-34.381 Y-55.210 Z-49.390
1286 L X-34.705 Y-55.329 Z-49.392
1287 L X-35.034 Y-55.426 Z-49.390
1288 L X-35.379 Y-55.518
1289 L X-35.723 Y-55.588
1290 L X-36.071 Y-55.646
1291 L X-36.434 Y-55.691
1292 L X-36.796 Y-55.720
1293 L X-37.531 Y-55.748 Z-49.397
1294 L X-44.518 Y-55.739 Z-49.393
1295 L X-114.929
1296 L X-122.691 Y-55.747 Z-49.396
1297 L X-123.424 Y-55.707 Z-49.391
1298 L X-123.784 Y-55.669
1299 L X-124.132 Y-55.613 Z-49.388
1300 L X-124.487 Y-55.544 Z-49.389
1301 L X-124.831 Y-55.463 Z-49.390
1302 L X-125.167 Y-55.369 Z-49.391
1303 L X-125.491 Y-55.258 Z-49.390
1304 L X-125.818 Y-55.133 Z-49.391
1305 L X-126.124 Y-54.998 Z-49.388
1306 L X-126.429 Y-54.851
1307 L X-126.734 Y-54.687 Z-49.389
1308 L X-127.021 Y-54.514 Z-49.390
1309 L X-127.291 Y-54.336 Z-49.389
1310 L X-127.573 Y-54.135
1311 L X-127.826 Y-53.934 Z-49.390
1312 L X-128.078 Y-53.720 Z-49.389
1313 L X-128.326 Y-53.488
1314 L X-128.560 Y-53.254 Z-49.390
1315 L X-128.777 Y-53.013 Z-49.389
1316 L X-128.997 Y-52.747
1317 L X-129.194 Y-52.493 Z-49.390
1318 L X-129.386 Y-52.220 Z-49.389
1319 L X-129.736 Y-51.642
1320 L X-129.893 Y-51.348 Z-49.388
1321 L X-130.044 Y-51.031 Z-49.392
1322 L X-130.171 Y-50.722 Z-49.391
1323 L X-130.288 Y-50.401 Z-49.390
1324 L X-130.397 Y-50.063 Z-49.389
1325 L X-130.489 Y-49.725 Z-49.390
1326 L X-130.567 Y-49.388
1327 L X-130.632 Y-49.033
1328 L X-130.679 Y-48.674 Z-49.389
1329 L X-130.746 Y-47.957 Z-49.397
1330 L X-130.739 Y-47.774 Z-49.390
1331 L Y-47.770
1332 L X-129.477 Y-47.759 Z-48.594
1333 L X-129.466 Y-47.593 Z-48.587
1334 L X-129.471 Y-47.242 Z-48.593
1335 L X-129.460 Y-42.728 Z-48.581
1336 L X-129.459 Y-27.290 Z-48.580
1337 L Y36.384
1338 L X-129.465 Y45.331 Z-48.586
1339 L X-129.472 Y47.178 Z-48.595
1340 L X-129.462 Y47.874 Z-48.587
1341 L X-129.447 Y48.215 Z-48.585
1342 L X-129.418 Y48.546 Z-48.584
1343 L X-129.373 Y48.854 Z-48.581
1344 L X-129.314 Y49.178 Z-48.584
1345 L X-129.160 Y49.785 Z-48.589
1346 L X-129.068 Y50.061 Z-48.587
1347 L X-128.958 Y50.352 Z-48.591
1348 L X-128.718 Y50.867 Z-48.590
1349 L X-128.425 Y51.378 Z-48.593
1350 L X-128.283 Y51.594 Z-48.592
1351 L X-128.107 Y51.839 Z-48.593
1352 L X-127.767 Y52.250 Z-48.594
1353 L X-127.563 Y52.468 Z-48.593
1354 L X-127.368 Y52.660 Z-48.596
1355 L X-126.943 Y53.024 Z-48.593
1356 L X-126.736 Y53.181 Z-48.594
1357 L X-126.511 Y53.339 Z-48.591
1358 L X-126.259 Y53.497
1359 L X-125.771 Y53.768 Z-48.592
1360 L X-125.488 Y53.899 Z-48.590
1361 L X-125.226 Y54.004 Z-48.588
1362 L X-124.951 Y54.102 Z-48.585
1363 L X-124.644 Y54.198 Z-48.583
1364 L X-124.342 Y54.277
1365 L X-124.046 Y54.339
1366 L X-123.725 Y54.393
1367 L X-123.392 Y54.430
1368 L X-122.736 Y54.473 Z-48.593
1369 L X-116.733 Y54.460 Z-48.581
1370 L X-110.422 Y54.459 Z-48.580
1371 L X-49.932
1372 L X-39.413 Y54.465 Z-48.586
1373 L X-37.227 Y54.477 Z-48.594
1374 L X-36.574 Y54.427 Z-48.582
1375 L X-36.244 Y54.388 Z-48.583
1376 L X-35.917 Y54.331
1377 L X-35.621 Y54.267
1378 L X-35.327 Y54.191
1379 L X-35.023 Y54.093 Z-48.585
1380 L X-34.740 Y53.990 Z-48.588
1381 L X-34.487 Y53.887 Z-48.590
1382 L X-34.207 Y53.755 Z-48.589
1383 L X-33.724 Y53.486 Z-48.590
1384 L X-33.469 Y53.326 Z-48.591
1385 L X-33.036 Y53.006 Z-48.592
1386 L X-32.806 Y52.817
1387 L X-32.422 Y52.450
1388 L X-32.217 Y52.232 Z-48.593
1389 L X-31.881 Y51.819 Z-48.592
1390 L X-31.554 Y51.341 Z-48.591
1391 L X-31.416 Y51.111 Z-48.590
1392 L X-31.271 Y50.843 Z-48.589
1393 L X-31.144 Y50.577
1394 L X-31.031 Y50.315
1395 L X-30.926 Y50.035 Z-48.585
1396 L X-30.830 Y49.746 Z-48.586
1397 L X-30.751 Y49.452 Z-48.584
1398 L X-30.682 Y49.145 Z-48.582
1399 L X-30.622 Y48.819
1400 L X-30.580 Y48.504 Z-48.581
1401 L X-30.551 Y48.179 Z-48.584
1402 L X-30.527 Y47.492 Z-48.594
1403 L X-30.540 Y42.628 Z-48.581
1404 L X-30.538 Y-44.293 Z-48.583
1405 L X-30.528 Y-47.267 Z-48.595
1406 L X-30.541 Y-47.950 Z-48.587
1407 L X-30.560 Y-48.292 Z-48.584
1408 L X-30.593 Y-48.624 Z-48.583
1409 L X-30.640 Y-48.938 Z-48.582
1410 L X-30.702 Y-49.246 Z-48.581
1411 L X-30.780 Y-49.563 Z-48.583
1412 L X-30.864 Y-49.855 Z-48.588
1413 L X-30.956 Y-50.128 Z-48.589
1414 L X-31.071 Y-50.419
1415 L X-31.321 Y-50.942 Z-48.592
1416 L X-31.460 Y-51.193 Z-48.591
1417 L X-31.610 Y-51.436 Z-48.595
1418 L X-31.932 Y-51.893
1419 L X-32.290 Y-52.316 Z-48.597
1420 L X-32.478 Y-52.513 Z-48.595
1421 L X-32.682 Y-52.710 Z-48.598
1422 L X-33.101 Y-53.063 Z-48.595
1423 L X-33.556 Y-53.386
1424 L X-33.791 Y-53.532 Z-48.593
1425 L X-34.050 Y-53.675 Z-48.592
1426 L X-34.563 Y-53.920 Z-48.587
1427 L X-34.844 Y-54.032 Z-48.588
1428 L X-35.127 Y-54.133 Z-48.590
1429 L X-35.724 Y-54.295 Z-48.585
1430 L X-36.031 Y-54.355 Z-48.583
1431 L X-36.342 Y-54.401
1432 L X-36.679 Y-54.437 Z-48.584
1433 L X-37.013 Y-54.457 Z-48.586
1434 L X-37.352 Y-54.463 Z-48.584
1435 L X-37.700 Y-54.473 Z-48.595
1436 L X-42.588 Y-54.460 Z-48.581
1437 L X-119.175 Y-54.462 Z-48.583
1438 L X-122.510 Y-54.474 Z-48.595
1439 L X-123.191 Y-54.450 Z-48.585
1440 L X-123.523 Y-54.421 Z-48.584
1441 L X-123.834 Y-54.376 Z-48.582
1442 L X-124.160 Y-54.316 Z-48.583
1443 L X-124.467 Y-54.247 Z-48.585
1444 L X-124.765 Y-54.166 Z-48.588
1445 L X-125.045 Y-54.073 Z-48.587
1446 L X-125.335 Y-53.963 Z-48.590
1447 L X-125.853 Y-53.725
1448 L X-126.120 Y-53.581 Z-48.592
1449 L X-126.361 Y-53.437 Z-48.594
1450 L X-126.580 Y-53.293 Z-48.592
1451 L X-126.826 Y-53.117 Z-48.594
1452 L X-127.238 Y-52.779
1453 L X-127.644 Y-52.386 Z-48.597
1454 L X-128.012 Y-51.958 Z-48.593
1455 L X-128.169 Y-51.755 Z-48.594
1456 L X-128.330 Y-51.527 Z-48.592
1457 L X-128.627 Y-51.035 Z-48.591
1458 L X-128.758 Y-50.788 Z-48.589
1459 L X-128.891 Y-50.506 Z-48.591
1460 L X-128.996 Y-50.246 Z-48.588
1461 L X-129.096 Y-49.969 Z-48.585
1462 L X-129.193 Y-49.666 Z-48.583
1463 L X-129.271 Y-49.365
1464 L X-129.335 Y-49.069
1465 L X-129.390 Y-48.744
1466 L X-129.428 Y-48.415 Z-48.582
1467 L X-129.477 Y-47.759 Z-48.594
1468 L X-130.387 Y-47.724 Z-49.242
1469 L X-130.397 Y-47.357 Z-49.249
1470 L X-130.388 Y-39.613 Z-49.244
1471 L Y-24.902
1472 L Y39.952
1473 L X-130.398 Y47.297 Z-49.250
1474 L X-130.387 Y47.665 Z-49.239
1475 L X-130.379 Y48.025 Z-49.238
1476 L X-130.358 Y48.384 Z-49.237
1477 L X-130.322 Y48.737 Z-49.236
1478 L X-130.268 Y49.072 Z-49.233
1479 L X-130.202 Y49.418 Z-49.235
1480 L X-130.031 Y50.079 Z-49.238
1481 L X-129.925 Y50.387 Z-49.236
1482 L X-129.805 Y50.705 Z-49.239
1483 L X-129.529 Y51.287 Z-49.237
1484 L X-129.366 Y51.583 Z-49.236
1485 L X-129.203 Y51.857 Z-49.238
1486 L X-129.034 Y52.110 Z-49.237
1487 L X-128.840 Y52.381 Z-49.238
1488 L X-128.647 Y52.623
1489 L X-128.445 Y52.859
1490 L X-128.218 Y53.101
1491 L X-127.995 Y53.323 Z-49.239
1492 L X-127.768 Y53.524 Z-49.237
1493 L X-127.511 Y53.738
1494 L X-127.268 Y53.923 Z-49.238
1495 L X-127.009 Y54.104 Z-49.237
1496 L X-126.730 Y54.280
1497 L X-126.175 Y54.591 Z-49.239
1498 L X-125.866 Y54.734 Z-49.238
1499 L X-125.568 Y54.855 Z-49.237
1500 L X-125.261 Y54.966 Z-49.235
1501 L X-124.930 Y55.070 Z-49.234
1502 L X-124.601 Y55.159 Z-49.235
1503 L X-124.275 Y55.232 Z-49.236
1504 L X-123.931 Y55.293
1505 L X-123.578 Y55.337 Z-49.235
1506 L X-122.878 Y55.397 Z-49.245
1507 L X-115.180 Y55.388 Z-49.244
1508 L X-49.136
1509 L X-38.577 Y55.395 Z-49.247
1510 L X-37.083 Y55.400
1511 L X-36.385 Y55.333 Z-49.234
1512 L X-36.034 Y55.287 Z-49.235
1513 L X-35.686 Y55.223
1514 L X-35.360 Y55.149
1515 L X-35.037 Y55.061
1516 L X-34.708 Y54.955
1517 L X-34.396 Y54.840 Z-49.237
1518 L X-34.105 Y54.721 Z-49.238
1519 L X-33.799 Y54.574 Z-49.237
1520 L X-33.246 Y54.265
1521 L X-32.965 Y54.088
1522 L X-32.702 Y53.900 Z-49.238
1523 L X-32.464 Y53.717 Z-49.237
1524 L X-32.209 Y53.506
1525 L X-31.979 Y53.295 Z-49.238
1526 L X-31.762 Y53.079 Z-49.237
1527 L X-31.534 Y52.837 Z-49.238
1528 L X-31.143 Y52.357 Z-49.237
1529 L X-30.950 Y52.084 Z-49.236
1530 L X-30.776 Y51.820 Z-49.237
1531 L X-30.616 Y51.553
1532 L X-30.456 Y51.258 Z-49.236
1533 L X-30.313 Y50.962 Z-49.237
1534 L X-30.184 Y50.667
1535 L X-30.067 Y50.356 Z-49.235
1536 L X-29.959 Y50.039 Z-49.237
1537 L X-29.870 Y49.715 Z-49.236
1538 L X-29.792 Y49.382 Z-49.234
1539 L X-29.724 Y49.035
1540 L X-29.676 Y48.694 Z-49.235
1541 L X-29.639 Y48.346 Z-49.237
1542 L X-29.602 Y47.625 Z-49.247
1543 L X-29.612 Y37.534 Z-49.244
1544 L X-29.608 Y-45.113 Z-49.246
1545 L X-29.602 Y-47.389 Z-49.249
1546 L X-29.624 Y-48.108 Z-49.238
1547 L X-29.650 Y-48.468 Z-49.237
1548 L X-29.691 Y-48.820 Z-49.236
1549 L X-29.746 Y-49.160 Z-49.235
1550 L X-29.818 Y-49.495 Z-49.233
1551 L X-29.903 Y-49.834 Z-49.235
1552 L X-29.996 Y-50.156 Z-49.237
1553 L X-30.102 Y-50.463 Z-49.238
1554 L X-30.229 Y-50.779 Z-49.237
1555 L X-30.512 Y-51.365
1556 L X-30.669 Y-51.648
1557 L X-30.837 Y-51.923 Z-49.239
1558 L X-31.205 Y-52.444 Z-49.238
1559 L X-31.614 Y-52.928 Z-49.240
1560 L X-31.831 Y-53.155 Z-49.238
1561 L X-32.062 Y-53.379 Z-49.241
1562 L X-32.288 Y-53.577 Z-49.239
1563 L X-32.544 Y-53.784 Z-49.238
1564 L X-32.802 Y-53.975 Z-49.239
1565 L X-33.062 Y-54.153
1566 L X-33.331 Y-54.320 Z-49.238
1567 L X-33.619 Y-54.481
1568 L X-33.895 Y-54.619 Z-49.236
1569 L X-34.199 Y-54.759 Z-49.235
1570 L X-34.509 Y-54.884 Z-49.236
1571 L X-34.821 Y-54.998 Z-49.238
1572 L X-35.474 Y-55.180 Z-49.236
1573 L X-35.808 Y-55.248 Z-49.235
1574 L X-36.145 Y-55.303
1575 L X-36.501 Y-55.345 Z-49.236
1576 L X-36.856 Y-55.373
1577 L X-37.214 Y-55.382 Z-49.237
1578 L X-37.577 Y-55.399 Z-49.250
1579 L X-44.129 Y-55.388 Z-49.244
1580 L X-119.993 Y-55.392 Z-49.246
1581 L X-122.642 Y-55.398 Z-49.247
1582 L X-123.360 Y-55.361 Z-49.238
1583 L X-123.712 Y-55.325 Z-49.237
1584 L X-124.050 Y-55.271 Z-49.233
1585 L X-124.397 Y-55.205 Z-49.234
1586 L X-124.731 Y-55.127 Z-49.236
1587 L X-125.056 Y-55.037 Z-49.238
1588 L X-125.368 Y-54.931 Z-49.236
1589 L X-125.685 Y-54.810 Z-49.238
1590 L X-126.269 Y-54.539 Z-49.236
1591 L X-126.564 Y-54.380 Z-49.238
1592 L X-126.838 Y-54.215
1593 L X-127.094 Y-54.046 Z-49.237
1594 L X-127.366 Y-53.852 Z-49.238
1595 L X-127.605 Y-53.663
1596 L X-127.845 Y-53.459
1597 L X-128.083 Y-53.236
1598 L X-128.306 Y-53.013 Z-49.240
1599 L X-128.511 Y-52.785 Z-49.237
1600 L X-128.724 Y-52.528
1601 L X-128.910 Y-52.288 Z-49.239
1602 L X-129.093 Y-52.028 Z-49.237
1603 L X-129.428 Y-51.474
1604 L X-129.578 Y-51.192 Z-49.236
1605 L X-129.725 Y-50.886 Z-49.238
1606 L X-129.846 Y-50.590 Z-49.237
1607 L X-129.959 Y-50.282 Z-49.235
1608 L X-130.064 Y-49.954 Z-49.234
1609 L X-130.153 Y-49.626 Z-49.235
1610 L X-130.227 Y-49.300 Z-49.236
1611 L X-130.289 Y-48.953
1612 L X-130.334 Y-48.603 Z-49.234
1613 L X-130.400 Y-47.903 Z-49.247
1614 L X-130.387 Y-47.724 Z-49.242
1615 L X-129.762 Y-47.792 Z-48.843
1616 L X-129.749 Y-47.634 Z-48.835
1617 L X-129.757 Y-47.277 Z-48.843
1618 L X-129.745 Y-41.179 Z-48.834
1619 L Y-28.484
1620 L Y36.782
1621 L X-129.751 Y45.729 Z-48.840
1622 L X-129.758 Y47.215 Z-48.844
1623 L X-129.743 Y47.920 Z-48.835
1624 L X-129.726 Y48.266 Z-48.833
1625 L X-129.694 Y48.604 Z-48.832
1626 L X-129.646 Y48.920 Z-48.828
1627 L X-129.585 Y49.252 Z-48.831
1628 L X-129.426 Y49.875 Z-48.835
1629 L X-129.329 Y50.161 Z-48.833
1630 L X-129.216 Y50.460 Z-48.837
1631 L X-128.964 Y50.995 Z-48.835
1632 L X-128.812 Y51.273
1633 L X-128.662 Y51.524 Z-48.838
1634 L X-128.511 Y51.751 Z-48.837
1635 L X-128.330 Y52.004 Z-48.838
1636 L X-127.973 Y52.435
1637 L X-127.762 Y52.660
1638 L X-127.558 Y52.861 Z-48.840
1639 L X-127.357 Y53.042 Z-48.837
1640 L X-127.115 Y53.241
1641 L X-126.898 Y53.407 Z-48.838
1642 L X-126.662 Y53.572 Z-48.836
1643 L X-126.402 Y53.735
1644 L X-125.895 Y54.019 Z-48.837
1645 L X-125.604 Y54.154 Z-48.836
1646 L X-125.330 Y54.264 Z-48.834
1647 L X-125.045 Y54.366 Z-48.832
1648 L X-124.732 Y54.464 Z-48.829
1649 L X-124.421 Y54.547 Z-48.830
1650 L X-124.116 Y54.612 Z-48.831
1651 L X-123.788 Y54.668
1652 L X-123.449 Y54.708 Z-48.830
1653 L X-122.780 Y54.759 Z-48.841
1654 L X-116.739 Y54.745 Z-48.834
1655 L X-40.523 Y54.748 Z-48.837
1656 L X-37.183 Y54.762 Z-48.843
1657 L X-36.516 Y54.704 Z-48.830
1658 L X-36.180 Y54.662 Z-48.831
1659 L X-35.847 Y54.604 Z-48.830
1660 L X-35.541 Y54.536
1661 L X-35.238 Y54.456
1662 L X-34.927 Y54.356 Z-48.831
1663 L X-34.635 Y54.250 Z-48.834
1664 L X-34.370 Y54.142 Z-48.836
1665 L X-34.082 Y54.005 Z-48.835
1666 L X-33.578 Y53.723 Z-48.836
1667 L X-33.316 Y53.558
1668 L X-32.862 Y53.222 Z-48.837
1669 L X-32.625 Y53.026
1670 L X-32.417 Y52.835 Z-48.838
1671 L X-32.221 Y52.641 Z-48.837
1672 L X-32.009 Y52.416 Z-48.838
1673 L X-31.657 Y51.982 Z-48.837
1674 L X-31.475 Y51.728 Z-48.835
1675 L X-31.317 Y51.487 Z-48.836
1676 L X-31.173 Y51.246
1677 L X-31.023 Y50.969 Z-48.834
1678 L X-30.890 Y50.694 Z-48.835
1679 L X-30.772 Y50.423
1680 L X-30.664 Y50.132 Z-48.831
1681 L X-30.564 Y49.836 Z-48.833
1682 L X-30.482 Y49.532 Z-48.831
1683 L X-30.410 Y49.217 Z-48.829
1684 L X-30.348 Y48.885 Z-48.830
1685 L X-30.303 Y48.562 Z-48.829
1686 L X-30.272 Y48.230 Z-48.832
1687 L X-30.243 Y47.533 Z-48.844
1688 L X-30.255 Y41.080 Z-48.834
1689 L Y25.998
1690 L Y-35.688
1691 L X-30.249 Y-45.820 Z-48.840
1692 L X-30.242 Y-47.304 Z-48.844
1693 L X-30.260 Y-47.998 Z-48.834
1694 L X-30.282 Y-48.346 Z-48.832
1695 L X-30.318 Y-48.684 Z-48.831
1696 L X-30.367 Y-49.006 Z-48.830
1697 L X-30.433 Y-49.322 Z-48.828
1698 L X-30.513 Y-49.646 Z-48.830
1699 L X-30.599 Y-49.947 Z-48.834
1700 L X-30.695 Y-50.230 Z-48.835
1701 L X-30.814 Y-50.529
1702 L X-31.075 Y-51.071 Z-48.837
1703 L X-31.219 Y-51.331 Z-48.836
1704 L X-31.375 Y-51.584 Z-48.839
1705 L X-31.711 Y-52.061
1706 L X-32.084 Y-52.502 Z-48.841
1707 L X-32.281 Y-52.708 Z-48.839
1708 L X-32.493 Y-52.914 Z-48.841
1709 L X-32.932 Y-53.283 Z-48.839
1710 L X-33.406 Y-53.620 Z-48.840
1711 L X-33.651 Y-53.771 Z-48.838
1712 L X-33.919 Y-53.920 Z-48.837
1713 L X-34.453 Y-54.175 Z-48.833
1714 L X-34.742 Y-54.292 Z-48.834
1715 L X-35.034 Y-54.397 Z-48.836
1716 L X-35.648 Y-54.566 Z-48.832
1717 L X-35.962 Y-54.627 Z-48.830
1718 L X-36.282 Y-54.677
1719 L X-36.625 Y-54.715 Z-48.831
1720 L X-36.965 Y-54.737 Z-48.833
1721 L X-37.310 Y-54.744 Z-48.832
1722 L X-37.662 Y-54.759 Z-48.845
1723 L X-42.580 Y-54.746 Z-48.835
1724 L X-119.190 Y-54.748 Z-48.837
1725 L X-122.550 Y-54.758 Z-48.845
1726 L X-123.243 Y-54.728 Z-48.833
1727 L X-123.581 Y-54.698 Z-48.832
1728 L X-123.900 Y-54.649 Z-48.829
1729 L X-124.232 Y-54.588 Z-48.830
1730 L X-124.548 Y-54.515 Z-48.832
1731 L X-124.854 Y-54.432 Z-48.835
1732 L X-125.143 Y-54.335 Z-48.832
1733 L X-125.442 Y-54.221 Z-48.835
1734 L X-125.979 Y-53.973
1735 L X-126.255 Y-53.824 Z-48.837
1736 L X-126.506 Y-53.673 Z-48.838
1737 L X-126.736 Y-53.522 Z-48.837
1738 L X-126.990 Y-53.341 Z-48.838
1739 L X-127.422 Y-52.986
1740 L X-127.643 Y-52.779
1741 L X-127.845 Y-52.576 Z-48.840
1742 L X-128.030 Y-52.371 Z-48.837
1743 L X-128.229 Y-52.131 Z-48.838
1744 L X-128.394 Y-51.917 Z-48.839
1745 L X-128.562 Y-51.679 Z-48.837
1746 L X-128.870 Y-51.168 Z-48.836
1747 L X-129.007 Y-50.911 Z-48.835
1748 L X-129.146 Y-50.622 Z-48.836
1749 L X-129.256 Y-50.351 Z-48.834
1750 L X-129.359 Y-50.065 Z-48.832
1751 L X-129.459 Y-49.754 Z-48.830
1752 L X-129.540 Y-49.445 Z-48.831
1753 L X-129.607 Y-49.140
1754 L X-129.665 Y-48.808
1755 L X-129.705 Y-48.473 Z-48.829
1756 L X-129.763 Y-47.804 Z-48.843
1757 L X-129.762 Y-47.792
1758 L X-130.062 Y-47.754 Z-49.058
1759 L X-130.055 Y-47.677 Z-49.055
1760 L X-130.066 Y-47.316 Z-49.063
1761 L X-130.056 Y-41.184 Z-49.056
1762 L Y-27.290
1763 L Y37.576
1764 L X-130.065 Y46.508 Z-49.062
1765 L X-130.068 Y47.254 Z-49.064
1766 L X-130.053 Y47.617 Z-49.053
1767 L X-130.047 Y47.970
1768 L X-130.028 Y48.323 Z-49.051
1769 L X-129.993 Y48.667 Z-49.050
1770 L X-129.941 Y48.992 Z-49.046
1771 L X-129.878 Y49.331 Z-49.049
1772 L X-129.714 Y49.972 Z-49.052
1773 L X-129.612 Y50.269 Z-49.050
1774 L X-129.496 Y50.576 Z-49.054
1775 L X-129.232 Y51.133 Z-49.051
1776 L X-129.075 Y51.420 Z-49.050
1777 L X-128.918 Y51.682 Z-49.053
1778 L X-128.760 Y51.921 Z-49.052
1779 L X-128.572 Y52.183
1780 L X-128.197 Y52.636
1781 L X-127.978 Y52.869
1782 L X-127.765 Y53.080 Z-49.054
1783 L X-127.552 Y53.271 Z-49.052
1784 L X-127.303 Y53.477
1785 L X-127.074 Y53.651 Z-49.053
1786 L X-126.827 Y53.824 Z-49.051
1787 L X-126.557 Y53.994
1788 L X-126.028 Y54.291 Z-49.054
1789 L X-125.728 Y54.430 Z-49.052
1790 L X-125.443 Y54.545 Z-49.051
1791 L X-125.148 Y54.651 Z-49.049
1792 L X-124.826 Y54.752 Z-49.047
1793 L X-124.507 Y54.838 Z-49.049
1794 L X-124.192 Y54.907
1795 L X-123.856 Y54.965
1796 L X-123.511 Y55.007 Z-49.048
1797 L X-123.166 Y55.035
1798 L X-122.827 Y55.068 Z-49.059
1799 L X-116.746 Y55.057 Z-49.056
1800 L X-40.123 Y55.060 Z-49.058
1801 L X-37.134 Y55.071 Z-49.062
1802 L X-36.453 Y55.004 Z-49.048
1803 L X-36.110 Y54.960 Z-49.049
1804 L X-35.770 Y54.899
1805 L X-35.455 Y54.828
1806 L X-35.142 Y54.744 Z-49.048
1807 L X-34.823 Y54.640 Z-49.049
1808 L X-34.521 Y54.530 Z-49.051
1809 L X-34.244 Y54.417 Z-49.053
1810 L X-33.947 Y54.275 Z-49.051
1811 L X-33.421 Y53.980
1812 L X-33.149 Y53.809
1813 L X-32.898 Y53.629 Z-49.052
1814 L X-32.673 Y53.457
1815 L X-32.427 Y53.254
1816 L X-32.209 Y53.053 Z-49.053
1817 L X-32.003 Y52.849 Z-49.052
1818 L X-31.784 Y52.616
1819 L X-31.413 Y52.160
1820 L X-31.226 Y51.897 Z-49.050
1821 L X-31.061 Y51.645 Z-49.051
1822 L X-30.908 Y51.391
1823 L X-30.754 Y51.106 Z-49.050
1824 L X-30.616 Y50.822 Z-49.052
1825 L X-30.492 Y50.539
1826 L X-30.380 Y50.238 Z-49.049
1827 L X-30.276 Y49.932 Z-49.051
1828 L X-30.191 Y49.619 Z-49.049
1829 L X-30.116 Y49.295 Z-49.048
1830 L X-30.051 Y48.956
1831 L X-30.004 Y48.625
1832 L X-29.969 Y48.285 Z-49.051
1833 L X-29.934 Y47.577 Z-49.063
1834 L X-29.944 Y39.511 Z-49.056
1835 L X-29.941 Y-44.708 Z-49.058
1836 L X-29.933 Y-47.345 Z-49.063
1837 L X-29.956 Y-48.051 Z-49.052
1838 L X-29.981 Y-48.405 Z-49.050
1839 L X-30.019 Y-48.749
1840 L X-30.071 Y-49.079 Z-49.049
1841 L X-30.141 Y-49.404 Z-49.046
1842 L X-30.223 Y-49.736 Z-49.048
1843 L X-30.313 Y-50.046 Z-49.051
1844 L X-30.413 Y-50.341 Z-49.052
1845 L X-30.536 Y-50.647 Z-49.051
1846 L X-30.808 Y-51.211 Z-49.052
1847 L X-30.958 Y-51.482 Z-49.051
1848 L X-31.120 Y-51.745 Z-49.054
1849 L X-31.471 Y-52.243 Z-49.053
1850 L X-31.862 Y-52.704 Z-49.055
1851 L X-32.068 Y-52.920 Z-49.053
1852 L X-32.289 Y-53.134 Z-49.056
1853 L X-32.502 Y-53.320 Z-49.054
1854 L X-32.748 Y-53.521 Z-49.053
1855 L X-33.243 Y-53.873 Z-49.054
1856 L X-33.499 Y-54.032 Z-49.052
1857 L X-33.777 Y-54.186
1858 L X-34.038 Y-54.317 Z-49.050
1859 L X-34.332 Y-54.452 Z-49.049
1860 L X-34.632 Y-54.573 Z-49.051
1861 L X-34.933 Y-54.683 Z-49.053
1862 L X-35.565 Y-54.858 Z-49.050
1863 L X-35.889 Y-54.922 Z-49.049
1864 L X-36.217 Y-54.975
1865 L X-36.566 Y-55.015
1866 L X-36.913 Y-55.040 Z-49.051
1867 L X-37.264 Y-55.048 Z-49.050
1868 L X-37.621 Y-55.068 Z-49.064
1869 L X-44.134 Y-55.057 Z-49.056
1870 L X-119.971 Y-55.060 Z-49.059
1871 L X-122.594 Y-55.067 Z-49.063
1872 L X-123.299 Y-55.030 Z-49.052
1873 L X-123.644 Y-54.997 Z-49.050
1874 L X-123.971 Y-54.945 Z-49.047
1875 L X-124.311 Y-54.881 Z-49.048
1876 L X-124.635 Y-54.806 Z-49.050
1877 L X-124.950 Y-54.720 Z-49.052
1878 L X-125.250 Y-54.618 Z-49.050
1879 L X-125.557 Y-54.501 Z-49.052
1880 L X-126.117 Y-54.241 Z-49.050
1881 L X-126.402 Y-54.088 Z-49.052
1882 L X-126.664 Y-53.930 Z-49.053
1883 L X-126.906 Y-53.771 Z-49.052
1884 L X-127.168 Y-53.583 Z-49.053
1885 L X-127.623 Y-53.210 Z-49.052
1886 L X-127.852 Y-52.996 Z-49.053
1887 L X-128.063 Y-52.784 Z-49.055
1888 L X-128.259 Y-52.567 Z-49.052
1889 L X-128.464 Y-52.319
1890 L X-128.638 Y-52.093 Z-49.053
1891 L X-128.814 Y-51.845 Z-49.052
1892 L X-129.135 Y-51.313 Z-49.051
1893 L X-129.278 Y-51.044 Z-49.050
1894 L X-129.421 Y-50.748 Z-49.053
1895 L X-129.536 Y-50.465 Z-49.051
1896 L X-129.644 Y-50.168 Z-49.049
1897 L X-129.746 Y-49.849 Z-49.048
1898 L X-129.832 Y-49.531 Z-49.049
1899 L X-129.902 Y-49.216
1900 L X-129.962 Y-48.877
1901 L X-130.037 Y-48.190 Z-49.051
1902 L X-130.072 Y-47.852 Z-49.062
1903 L X-130.062 Y-47.754 Z-49.058
1904 L Z15.381 FQ3
1905 L FMAX M9 ;
1906 L Z-1 R0 FMAX M91
1907 L Y+580 FMAX M91
1908 L FMAX M05 ;
1909 CYCL DEF 32.0 TOLERANCE
1910 CYCL DEF 32.1
1911 L M30
1912 END PGM 2krs MM
######DRILLING######
10 BEGIN PGM 20 drill MM
11 ; Date : 03.12.07 - 21:56:01
12 BLK FORM 0.1 Z X-136.575 Y-105.432 Z-70.
13 BLK FORM 0.2 X136.575 Y105.432 Z0.0
14 ; TOOL TYPE : DRILL
15 ; TOOL ID : 20 drill
16 ; TOOL DIA. 20. LENGTH 100.
17 TOOL CALL 21 Z S200 DL+0.0 DR+0.0
Q1= 100 ; PLUNGE FEEDRATE
Q3= 13000 ; SKIM FEEDRATE
21 ;
22 ; TOOLPATH : 20 drill
23 L X0.0 Y0.0 FQ3 M03
24 L Z10.000 M8
25 L X80.000 Y40.000
26 CYCL DEF 203 UNIVERSAL DRILLING~
Q200= 5.000 ; CLEARPLANE~
Q201= -70.000 ; HOLE DEPTH~
Q206= 100 ; PLUNGE FEEDRATE~
Q202= 10.000 ; PECKING DEPTH~
Q210= 0.0 ; DWELL TIME AT TOP~
Q203= +0.0 ; SURFACE COORDINATE~
Q204= 10.000 ; 2ND SET-UP CLEARANCE~
Q212= 0.0 ; PECK DECREMENT~
Q213= 7 ; NUMBER OF PECKS~
Q205= 0.0 ; MIN. PECK DEPTH~
Q211= 0.0 ; DWELL TIME AT BOTTOM~
Q208= 9999 ; RETRACTION FEED RATE~
Q256= 0.200 ; CHIPBREAK DIST.
27 L X80.000 Y40.000 R0 FMAX M99
28 L X0.0 Y0.0 R0 FMAX M99
29 L Z10.000 FMAX
30 L FMAX M9 ;
31 L Z-1 R0 FMAX M91
32 L Y+580 FMAX M91
33 L FMAX M05 ;
34 CYCL DEF 32.0 TOLERANCE
35 CYCL DEF 32.1
36 L M30
37 END PGM 20 drill MM
could you send me your post for investigation?
[QUOTE=could you send me your post for investigation?[/QUOTE]
I am reluctant to send you my post as it has been very heavily modified to meet my requirements. I know that SolidCAM have a H'hain post for your machine, in fact you may have a working post in the bundle of post processors that come with SolidCAM as standard.
Look in C:\Program Files\SolidCAM2007R11.1\GPP for files with the suffix *.mac and *.gpp.
Do you have a problem with your reseller?
