587,082 active members*
2,790 visitors online*
    Apr 2003
    159
    solenoid help
    I'm building a small 2 axis plotter to print on cd's.it will print around the circumference of the cd (circular).
    I plan on using a solenoid for pen up/down, what I need is a schematic for the solenoid, using the Z setting (standard G code from Desk Engrave)
    to latch a solenoid down, then up when the Z setting requires it.
    Thank for looking. jimini
    Dec 2003
    24223
    You don't mention what control software you are using, I believe the Desk Engrave is just CAM software, no?
    If so they probabally stipulate a Z height for a normal Z Axis position, What would probabally work better in your instance is two M codes one for pen down & one for pen up. as you probabally do not require any z axis control?
    A 24vdc solenoid could be used with a 2n7000 transistor if fed from the printer port.
    Al.
    Albert E.
    Apr 2003
    159
    I'll be using Mach3 that's why I was concerned about the Z height, deskengrave inserts it automatically as you know.
    I guess I'll have to play with it a bit. Thanks. Jim
  1. Pneumatic solenoid help
    By Cold Fusion in forum Community Club House
    Last Post: 05-29-2006, 06:46 AM
  2. Solenoid Z-Axis?
    By chuckknigh in forum DIY CNC Router Table Machines
    Last Post: 10-09-2003, 12:57 AM
