587,672 active members*
3,893 visitors online*
IndustryArena Forum > CAD Software > Uncategorised CAD Discussion > software to convert spline curve to tangent arcs
Results 1 to 11 of 11
    Sep 2009
    1
    Is there any CAD package that can automatically covert a spline curve (from DXF file) to a series of a tangent arcs?
    Sep 2008
    117
    Sent you a PM
    Gene
    Dec 2006
    5
    I use Visicam from Vero Intl.
    Edit - curve/polyline to lines/arcs is the command
    select segments, arcs or segments and arc output, maintain tangency checkbox, cordal tolerance option, angular angle option, maximum radius option
    - sound complicated, but I just go "Edit - curve/polyline to lines/arcs"
    select segments and arcs - enter in a tolerance and I'm done - that 3 - 5 seconds
    good luck finding another solution - if you do, let me know
    thanks
    Feb 2010
    0
    I need the same software myself.
    Is there a freeware that converts spline/ellipse to arcs? (with DXF)
    Sep 2008
    117
    Quote Originally Posted by carbo20 View Post
    Can you post a sample file?
    Gene
    Feb 2010
    0
    I'm attaching the file.
    it's a simple dxf with spline that i need to convert to arcs in order to use my "OPTOCAD" software .
    Nir
    Attached Files Attached Files
    35538
    Here you go
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Feb 2010
    0
    Thank you very much Gery.
    Do you know any freeware that i can use for this work?
    NIr
    35538
    Sorry, no. But, if you save it as a v12 .dxf, the spline should get converted to short, straight line segments., if that will work for you.
    Gerry
    Feb 2010
    0
    Thank you Gery.
    It works!
    Re: software to convert spline curve to tangent arcs
    Stéphan Hales
  1. Convert spline to arcs or lines
    By mattpatt in forum Solidworks
    Last Post: 12-19-2012, 03:05 AM
  2. rotating a large arc or spline to tangent on 2 arcs
    By beekeeper in forum Mastercam
    Last Post: 12-12-2011, 12:20 PM
  3. Replies: 5
    Last Post: 09-09-2009, 01:58 PM
  4. Tangent Arcs Mastercam 9.1
    By taa1967sma in forum Mastercam
    Last Post: 03-23-2009, 08:47 PM
