We have to mills with centurion 7 controls. On the RW20 when verifying the tool path it sorta paints in the tool path while cutting the VM30XP does not it just shows the cutter following the tool path. Is there a setting to change this in the control ? Also can you change it in he offline programing software ?
Bill
