587,434 active members*
3,029 visitors online*
Results 1 to 11 of 11
    Mar 2010
    0
    SmartProbe.ngc / G38.4 not working
    Hi I'm rather new to EMC but wanted to give probing a try, gridprobe.ngc works just fine, but when I tryed smartprobe it would do its initial decent and when the probe tripped it would just hang there. upon further troubleshooting I realized the the G38.4/G38.5 just doesnt work, I get a message that the probe is already clear which is not the case verified thru Halmeter and by running a G38.2 which would give a message that the probe is already tripped.
    I am running EMC 2.3.5
    any help is appreciated.
    Mar 2010
    0
    I have tried compiling both 2.3.0 and 2.5-pre and both have the exact same issue, I have also tried creating a new config with stepconf and no change there either. am I alone on this one?
    Mar 2010
    0
    after further fooling around i discovered that G38.4 will actually work if I invert the parport input (change parport.0.pin-15-in to parport.0.pin-15-in-not) very strange. this of course is no helpful to me since I have a NC probe.
    Is there a workaround to invert further down the line perhaps?
    Mar 2010
    0
    I was able to get it working by using ladder to invert the inverted input required to make g38.4/38.5 work. if any body has the same issue and wants further details about the work-around let me know
    Nov 2008
    24
    More details please.
    It looks like I'm hitting the same problem. Any additional details you can provide would be appreciated so I don't have to reinvent this. Much thanks.
    Aug 2007
    7
    Apr 2005
    27
    Is there any chance that this fix will be available as an update, if not how long will we have to wait for the next release that fixes this problem?
    thanks
    Nov 2005
    496
    according to the logs: this bug fix has been placed in the 2.4.
    When the next bug release is has not been stated that I know of.
    Chris
    Apr 2005
    27
    Hmm, I must be doing something wrong because it's not working for me in 2.4
    Quote Originally Posted by chester88 View Post
    Chris
    Nov 2005
    496
    I wasn't clear.
    its been added to the 2.4 repository but has not been released yet (2.4.7)
    Chris
    Apr 2005
    27
    Ah, thank you. I guess I will wait for the next update.
  1. Not working
    By mmachining in forum BobCad-Cam
    Last Post: 02-06-2010, 03:50 PM
  2. G96 not working as it should
    By mbpp in forum G-Code Programing
    Last Post: 06-14-2009, 01:51 PM
  3. G76 not working
    By cadman@teluspla in forum G-Code Programing
    Last Post: 08-11-2008, 09:47 PM
  4. THC-300 not working
    By bad-rat-57 in forum Waterjet General Topics
    Last Post: 07-31-2008, 05:13 AM
  5. She was working
    By utengineer04 in forum Bridgeport / Hardinge Mills
    Last Post: 07-26-2005, 03:39 AM
